PASS system
Old Jan 2, 2002 | 04:34 PM
Andy Fanshawe's Avatar
Car: 91 camaro rs
PASS system
Can anyone explain to me the PASS system as installed in camaros? I am hoping to buy a 1991 RS Camaro that has got no keys and no ECU! (No engine or gearbox either!!). Will the replacement ECU need matching in to the new key?
Old Jan 2, 2002 | 06:16 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
No, the ECU doesn't care. It get a "go" signal from the passkey module once it senses a valid ignition key. The passkey modual is about the size of two packs of cigs side by side behind the centermost dash deeply buried.
the passkey module must match the key for it to work. You could of course tell the ECU not to look for passkey if you burn a new chip.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
customblackbird
Oct 1, 2015 04:30 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
84 TA NV
Sep 6, 2015 08:02 PM
