Low Oil Pressure
Old Jan 3, 2002 | 12:49 AM
BigMike 92 Z28's Avatar
Low Oil Pressure
I noticed latly that my in dash oil pressure gauge is lower than my brothers is ( has a new 305 in a 85 Firebird ). Usually when I am driving it reads about 30( in the middle ) maybe a little more but sometimes At Idle it drops down to top of red and even a ways into red. I now this cant be good. I have 100k on the motor- think its finally time for a rebuild or do you guys think its something else. Also it runs very strong still.
Old Jan 3, 2002 | 09:28 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
small blocks often have low op at idle
Even new ones. Rod side clearance has a lot to do with it. If it comes up as soon as you touch the gas I would not worry about it.
10psi at idle is sufficent in most cases. You might get some rockers making noise but thats about it.
Old Jan 3, 2002 | 05:28 PM
cool- thanks
Old Jan 3, 2002 | 09:38 PM
82camaro's Avatar
Car: 82 camaro SC
Stock guages are prone to not being very accurate. If you are concerned, check it with a mechanical guage. I agree with what he said above 10 psi at idle and 10 psi for every 1000 rpm after that is plenty.
Old Jan 4, 2002 | 02:29 PM
BigRuss's Avatar
Oil pressure started to drop in mine like that just before the bearings went out on cylinder six. If you start hearing a slight knocking noise at idle and the oil pressure drops with every knock, you know your bearings have had it; clearance is getting too large from excessive wear. I owned mine for a little over a week before this happened. And I made the previous owner help me rebuild the dam thing...
Old Jan 4, 2002 | 05:29 PM
ede's Avatar
ede
if you want to be sure put a mechanical gauge on and check it. 10 psi for every 1000 rpm is accepted as "normal".
Old Jan 8, 2002 | 03:57 AM
1990IROC-Z's Avatar
I had the same problem unitl recently; I suspected it wasn't my pressure when it started dropping down to about 0 at idle in gear. I changed the oil pressure sending unit and now my pressure looks where it should. Didn't get to double check it with a mechanical which I really want to do to see how the stock gauge fairs in the accuracy department.
89GTAOz
May 16, 2020 09:31 AM
xxx3man`
Sep 23, 2015 10:37 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
