Gas tank pressure.
Old Oct 2, 2017 | 05:52 AM
Rhp454's Avatar
Car: 1986 Z-28
Engine: 305cu
Transmission: automatic O/D
Axle/Gears: open, 2:73
Gas tank pressure.
How much pressure is too much pressure that builds up in my gas tank on my 1986 Z28, 305cu with carb? Would it be ok if I alleviate the pressure by taking off the one way inlet valve that is above the rear axle on dr side and replace it with an inline air filter with and loop the gas line? This will let the tank breath in and out. Then I could disconnect the charcoal filter can and alleviate on less vacuumline.
Old Oct 2, 2017 | 10:06 AM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Re: Gas tank pressure.
What is your car doing that you need to vent the tank other then the factory did?
TheSwarm666X
Jul 26, 2017 10:12 PM
slowTA
29
Feb 12, 2017 03:11 PM
Cheath16
Carburetors
Oct 31, 2016 04:47 PM
gnandiroczguy
Oct 18, 2016 09:33 AM
Blue91
Car Audio
Nov 6, 2001 08:22 PM
