Is there any way to minimize this?
Old Oct 2, 2017 | 07:27 PM
NoEmissions84TA's Avatar
I borrowed this picture, hope you don't mind Chuck.
I have to ask - what causes this buildup, and are there ways to minimize it?
It seems that some engines and different types of ignition systems are more prone to it.
Old Oct 2, 2017 | 07:42 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Is there any way to minimize this?
I would think wire and plug resistance being high could cause more carbon buildup.
Old Oct 4, 2017 | 05:18 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Hard to say. I've had some that get bad buildup and some that don't.
Old Oct 4, 2017 | 07:07 PM
zed-028's Avatar
Car: 1987 Z28 Camaro
Engine: 305 LG4 4bbl
Transmission: TH700R4
moisture is a factor aswell
Old Oct 4, 2017 | 07:25 PM
Engine: Lb9
Transmission: M20
They did make a rotor for gm small cap remote coil tbi and tpi to help with moisture acdelco D461 gm 10477219 the bottom of the rotor has fins to help move air and moisture out the bottom of the distributor base vent screens.Attachment 364748
Old Oct 5, 2017 | 01:04 AM
I will have to try that next time on my truck.
Old Oct 5, 2017 | 01:23 PM
Engine: Lb9
Transmission: M20
Check the screen at the base of the distributor for being plugged too.
Old Oct 5, 2017 | 05:16 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
I would also guess moisture.
Old Oct 5, 2017 | 07:41 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
When you combine High voltage with anodized metal and throw in a dash of humidity, you will get carbon build up. Or, maybe it gets dizzy and throws up inside.
Old Oct 7, 2017 | 10:29 PM
cardo0's Avatar
Car: Fourth Gen '94 camaro
Engine: 350 Gen II
Transmission: A4
How much plug gap do you run? How many miles?
Old Oct 7, 2017 | 11:35 PM
GeneralDisorder's Avatar
Indeed - larger plug gap will increase secondary voltage and erode all your points faster. Running the smallest plug gap that will do the job will put the lowest strain on all ignition components. The secondary voltage rises till it jumps the gap at the plug (or the cap/rotor if that gap is greater). That's why the plugs stop firing if the gap get a too large - the coil can't generate enough voltage to do it. Also puts a huge strain on the coil and the wires, etc. Prolonged excessive plug gap will destroy the insulation on wires and burn up coils.
GD
Old Oct 8, 2017 | 12:40 AM
Just generalizing. It just that some vehicles do this more than others.
GD - remember those .060" and greater plug gaps GM used to recommend?
Old Oct 8, 2017 | 12:53 AM
From what I understand, the larger gaps were to insure combustion with ultra lean mixtures that were notoriously difficult to ignite..... It's not a "performance" modification.... I have run .035 to .045 in virtually everything I've ever built of any make or model. You are generally always pretty rich when your trying to make power and it's pretty easy to ignite a nice rich mixture so I've never needed to increase a plug gap.
All it has to do is start the combustion. The shortest gap that will do this 100% of the time is the ticket in my experience.
GD
Old Oct 9, 2017 | 02:43 PM
z 28 jari's Avatar
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
Does that finned #10477219 help to carbon buildup?
Old Oct 9, 2017 | 02:56 PM
Engine: Lb9
Transmission: M20
AFAIK it’s to help with moisture
Old Oct 9, 2017 | 03:09 PM
z 28 jari's Avatar
Engine: 385
Just ordered one.If it vented dist cap inside better than standard one it's worth it.
Old Oct 9, 2017 | 04:30 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Not so much moisture, but ozone. The ribs are to help with ventilation, but to remove ozone, not moisture.
http://www.technicianstoolbox.com/in...x=4&topicId=23
http://www.farmallcub.com/phpBB2/viewtopic.php?t=6568
http://www.wellsve.com/counterpoint_issues04-06.html
Old Oct 9, 2017 | 07:46 PM
Maybe some of us should connect a small vacuum line to our distributors???
I would be one to try it.
Old Jan 24, 2018 | 03:20 PM
Biggd4355's Avatar
Have you ever examined a distributor for a marine application? The engines are the same. But the cap has a hole in it with a screen in it to allow moisture to escape. So why wouldn't it help get rid of moisture in an automotive environment?
Biggd4355's Avatar
add a vacuum leak and you will notice your idle go up.
Old Jan 24, 2018 | 05:27 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
On my Vortec 350 Express van I actually hooked up a small vacuum line to a port I added slightly above the throttle plate in the throttle body. I hooked a vent line to the intake duct. Anytime the engine was above idle it had ported vacuum to the distributor cap to purge out the moisture and ionized air. Went from having to change the cap and rotor practically yearly to lasting almost 4 years before the CNP 24x swap.
Old Jan 26, 2018 | 12:48 AM
I am going to try this, but I will use a restriction in the vacuum line.
No need for a 20 gallon Shop Vac to be connected to the distributor.
