New roller lifters old cam
Old Nov 8, 2017 | 08:47 PM
Birddog87's Avatar
This may be a dumb question but i am doing my first full engine rebuild and i was just curious if i can run hydraulic roller lifters with the cam thats already in my 302 windsor or do i need a new cam for the new rollers and lifters?
thanks
Old Nov 8, 2017 | 09:38 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: New roller lifters old cam
Is the cam designed for hydraulic roller lifters?
Is the block designed for roller lifters or are the lifters an aftermarket retrofit?
You can't put roller lifters on a flat tappet cam.
You can't put a hydraulic lifter on a solid cam.
You can't put solid lifters on a hydraulic cam.
You can't put used flat tappet lifters on a cam lobe that the lifter did not come off of.
You can put flat tappet lifters back on the same lobes on the cam they came off of.
You can put new lifters on a used cam.
You can put used hydraulic roller lifters on a hydraulic roller cam (new or used).
You can put used solid roller lifters on a solid roller cam (new or used).
Old Nov 9, 2017 | 03:52 AM
Birddog87's Avatar
Thanks I'm tearing the motor down now I was just ordering parts and didn't want to order all New roller lifters without a cam if it was necessary which it is. The motor has many New parts on it so I'm not too sure what I'll find when I get to the guts.
Thanks for he help
Old Nov 10, 2017 | 04:11 PM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Dont order til you know what you got
Roller lifters are easy to ck for wear make sure your cam is good to
FireDemonSiC
Sep 24, 2022 07:00 PM
COSPEED
Sponsored Vendors
Feb 24, 2017 05:06 AM
86CamaroDan
Feb 22, 2017 04:40 PM
antman89iroc
Oct 26, 2016 01:01 PM
UltRoadWarrior9
Sep 23, 2016 06:38 PM
