Can’t seem to find the other end of this hose
Old Nov 17, 2017 | 05:50 AM
Bluegoose95401's Avatar
trying to find the other end of this hoes so I can hook my cruse control back together but I just can’t serm to find if any ideas?
Old Nov 17, 2017 | 06:22 AM
Big&BadGTA's Avatar
Engine: 5.7L L98 TPI
Transmission: 700r4 Automatic
Re: Can’t seem to find the other end of this hoes
Check the dimly lit corner for the other hoes.... should be visible.
Old Nov 17, 2017 | 06:26 AM
how far in to the corner are we talking when I had the batary out I coulnt see any thing. Where does this end connect to maybe I can back trace it if all else fails
Old Nov 17, 2017 | 06:38 AM
Big&BadGTA's Avatar
Not quite sure on that, but usually the hoes tend to stick together in the area.
The problem with the hoes I hear, is their connection point gets loose over time so the connection doesn't stay in very easy...
Wear a glove when reaching in there, and careful of any fluids.
I hope this helps.
Old Nov 17, 2017 | 08:09 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I hope this helps.
LMFAO
I believe that hose goes to a vacuum canister under the tray where the battery is. And judging by the dryness of what is in your hand, I would suggest replacing all of that circuit, at least, if not all your vacuum hoses under the hood
Old Nov 17, 2017 | 08:23 AM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Originally Posted by scooter
LMFAO
me too
Old Nov 17, 2017 | 08:25 AM
Drew's Avatar
Sphere of Destiny underneath the battery tray, below the whorns.
Old Nov 17, 2017 | 08:41 AM
Big&BadGTA's Avatar
LMFAO
In a pinch, if the hose, while in your hand, shows some signs of dryness, you can use a non-petroleum based lubricant of gel which might help.
Old Nov 17, 2017 | 09:39 AM
Rob's 92 gta's Avatar
Car: 92 firebird gta
Engine: L98 with minor mods.
I want to say it goes to a vac. ball under the battery tray as Drew said. Hope this helps
Old Nov 17, 2017 | 10:30 AM
86LG4Bird's Avatar
Stop it now!
Old Nov 17, 2017 | 10:50 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Use to do a lot of hoes chasing back in the day myself
Old Nov 17, 2017 | 11:04 AM
Big&BadGTA's Avatar
If that's the case, it's entirely possible that too much suction in the ball area caused premature release due to pressure from the hoes. Gotta be especially careful as these parts get older, one might suppose.
Old Nov 17, 2017 | 11:07 AM
86LG4Bird's Avatar
Hey, I resemble that remark
Old Nov 17, 2017 | 11:33 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
I think the vacuum hose goes to a brake switch then manifold vacuum. You might want to ask on this thread for the diagram.
https://www.thirdgen.org/forums/tech...iagrams-i.html
It could go to the vacuum bulb under the tray that the cruise control is on.
Here’s a diagram. Looks like drew is right.
Old Nov 17, 2017 | 12:16 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
My name isn't Drew
Old Nov 17, 2017 | 12:19 PM
Engine: Lb9
Transmission: M20
My name isn't Drew
I guess you got it first I was referring to Post 7
Old Nov 17, 2017 | 05:33 PM
zya5point0's Avatar
Car: 87 IROC
Transmission: auto
Hoes...oy vey
Old Nov 17, 2017 | 10:43 PM
Jbuchanan's Avatar
Car: 1987 GTA
Engine: 5.0
Transmission: Automatic
When your hoes become disconnected it means as previously stated it's gotten dry and worn slap out, probably time to upgrade all your hoes to new ones.
Old Nov 20, 2017 | 05:32 PM
zed-028's Avatar
Car: 1987 Z28 Camaro
Engine: 305 LG4 4bbl
Transmission: TH700R4
thoroughly entertaining reading, quality shenanigans, would read again 8/10
Old Nov 23, 2017 | 06:42 PM
Big&BadGTA's Avatar
...wonder if the original poster was able to figure out his hoes?
Old Nov 23, 2017 | 07:01 PM
Jbuchanan's Avatar
Car: 1987 GTA
Engine: 5.0
It took me years to get my hoes in check.
Old Nov 30, 2017 | 07:23 AM
[QUOTE=Big&BadGTA;6185142]...wonder if the original poster was able to figure out his hoes?[/QUOTE
​​ya I got my all hoes back in line, just takes a bit it’s kinda hard to raise that pi$( hand with the little space given under the batary tray. But with a bit of work and and a lot of patience I got the all back in line. So they hopefully won’t be acting up for a while, cause any one who’s any knows the trouble that outta line hoes can cause. Thanks for all the help and a good laugh I was able to locate the correct spot for this hose once Im done with the steering column I will replace that whole vacume circuit
Old Nov 30, 2017 | 11:08 AM
Ct1987's Avatar
A hoe by any other name is still a hoe.......don't forget to wrap that rascal.
Louis
Old Nov 30, 2017 | 09:56 PM
IROCZman15's Avatar
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
tooooo funny! all of it!!!
Old Dec 2, 2017 | 10:18 AM
OrangeBird's Avatar
Car: 1989 Firebird
And when you need diagrams for that "vacume" circuit , there is a thread around here someplace that has every year's vacuum diagram . With cute lil pictures of ALL the hoes
Old Dec 2, 2017 | 11:15 AM
Big&BadGTA's Avatar
...did someone say, pics of cute lil hoes?
