New Cam-Evaluation Please
Old Dec 19, 2017 | 08:37 PM
Green89IROC305's Avatar
Car: 91 Z28 - using 87 electricals
Engine: 383 HSR EBL
Transmission: 700R4 - Stage 3 Fixed Pressure
Axle/Gears: GM 3.08 POSI
Hey All,
I am having my 87 TPI drive train dropped into an 88 donor body as the 87 is a lost cause .
Anyway, they are going to polish up the intake and I was thinking this was a good time to swap the cam.
This is the cam I was looking at on Summit Here
I am not 100 percent sure what is in mine as it is a non stock 350 70's reproduction crate motor(came with the car).
Near as I can tell these are the specs of the motor based only on head casting numbers. The motor is using the stock TPI for a 350.
Horsepower: 249 HP @ 5,000 RPM
Torque: 304 Ft/Lbs @ 3,500 RPM
Compression Ratio: 8.50 to 1
Block: 4 – Bolt, 2 Piece Rear Seal, 4.000” Bore
Crankshaft: Cast Nodular 3.480” Stroke
Heads: Cast Iron, 76cc
Valves: 1.940” / 1.500”
Camshaft lift: 0.390” / 0.410” Hydraulic
Duration @ 0.050”: 195° / 202°
Could someone with more experience with cams let me know if my choice will net any performance? I am not looking for anything crazy, just better than what I have.
Thanks.
Old Dec 19, 2017 | 09:12 PM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Re: New Cam-Evaluation Please
yes, it will make a big difference in performance.
Just check to make sure you have retainer-to-seal clearance on those heads at the higher valve lift.
Old Dec 19, 2017 | 11:00 PM
Engine: 383 HSR EBL
Will do thanks!
Thomas Aquinas
Feb 10, 2005 02:34 PM
John Millican
Apr 30, 2002 08:28 AM
Sharky
Jun 22, 2001 06:49 AM
johnyIROC
Mar 19, 2001 07:27 PM
