Exhaust manifold bolts coming loose
Old Jan 2, 2018 | 09:44 AM
Jimmy2x's Avatar
Car: 1987 IROC-Z
Engine: 5.7L TPI
Axle/Gears: Borg Warner 9 bolt with 3.27
Other than purchasing new locking hardware, is there anything that will help keep exhaust manifold bolts from coming loose? I have been reluctant to use red or blue locktite assuming that it will not hold up to the heat or that I won't ever be able to remove the bolts again.
I removed my exhaust manifolds to reseal all my head bolts and noticed that half of the bolts were finger tight.
Old Jan 2, 2018 | 12:13 PM
gt4373's Avatar
Transmission: 5-Speed Manual
Re: Exhaust manifold bolts coming loose
These Are Relatively Cheap.
Old Jan 2, 2018 | 12:51 PM
Jimmy2x's Avatar
Car: 1987 IROC-Z
Engine: 5.7L TPI
Pardon my ignorance, but what are those? How do they work?
Old Jan 2, 2018 | 01:10 PM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
What kind of manifold gaskets are you using?
I use the OEM embossed steel shim gaskets and have never had one problem with manifold bolts coming loose ....multiple vehicles .... never.
Old Jan 2, 2018 | 01:24 PM
Jimmy2x's Avatar
Car: 1987 IROC-Z
Engine: 5.7L TPI
The gaskets are the steel shim type. Don't know if they are OEM or not though. Like many items on my car, I don't know what the previous owner did. Maybe he didn't tighten them very well and I just don't know any better.
Old Jan 2, 2018 | 04:04 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Cast iron manifolds on cast iron heads? Make sure manifolds are flat, no gaskets and tighten bolts like the factory.
Old Jan 2, 2018 | 07:16 PM
gt4373's Avatar
Those Are Exhaust Manifold Bolt Locks,The Ears Are Bent Over The Flat Of The Bolt Head And Locks Them In Place,My Car Still Has Them On From The Factory,Although I Noticed One Has Rusted Out Which They Will Do On Cars As Old As Ours.
Old Jan 3, 2018 | 07:14 AM
Jimmy2x's Avatar
Car: 1987 IROC-Z
Engine: 5.7L TPI
Great. Thank you for the suggestion and free education. Sometimes I feel like a real dumbass. My factory units are long gone.
Old Jan 3, 2018 | 08:49 AM
Jimmy2x's Avatar
Car: 1987 IROC-Z
Engine: 5.7L TPI
By the way, any idea where I might be able to find a set of those? Looked all over on line and nobody seems to have them for an 87 camaro.
Darkshot
Aug 5, 2009 07:35 PM
magadith
Feb 25, 2006 09:15 PM
Orr89RocZ
Nov 9, 2004 10:30 PM
monte-ss
Jan 12, 2002 06:48 PM
Mark_ZZ3
Mar 21, 2001 08:18 AM
