header bolts keep coming loose?
Old Oct 25, 2004 | 11:38 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I got my hooker shorties put on by a guy who owns his own garage and he recommended ARP bolts. He said that they would need tightened occasionaly for alittle while during the first month or so and then they would eventually settle and stay tight. So i tightened them and checked them periodically and they remained tight.
Now, a few weeks ago, my dad noticed a ticking sound coming from the passenger side header. An exhaust leak i guess. so i checked the bolts and they were real loose. Damn, its been a year so far and the bolts have been fine. So i retightend them and the noise went away. Well two weeks later, i came home for the week end and took the beast out for a spin for the last time before winter, and the leak was back.
Arent these bolts supposed to stay tight? Can I put lock tight on them? Space is real tight in there and i dont want to take the bolts out to put lock tite on them, cuz i might not be able to get them back in. I dont want to take off allot of stuff to get to the header. I got small hands and can get a wrench on them bolts but should they be coming loose?
Old Oct 25, 2004 | 05:48 PM
BWW's Avatar
BWW
Header bolts, if they are non-locking come loose quite often. If your bolts have a lock washer like a stage 8 bolt does then they should not come loose. However, if your exhaust system is not properly supported, the excess vibration could cause the bolts to come loose. Even though you had no problems with the bolts for a year,I am not surprised that the bolts slowly, or for whatever reason came loose. I suggest you get some locking bolts and since I have never used lock-tite on header bolts I cannot comment on the effective ness. Or just keep an 11mm wrench handy.
Old Oct 26, 2004 | 10:43 AM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
I have to agree. There are very few people who have had luck keeping non locking header bolts from turning out. You might be able to find 100 people on these boards who have but there are millions with headers that have not been able to. Your best bet is to go with locking header bolts. I swear by Stage8 locking bolts. They work great. Another alternative is the breslin split locking bolts. There are a few companies that make these and this could be an alternative for ya.
Here is the link for them from Jegs:
http://www.jegs.com/cgi-bin/ncommerc...24&prmenbr=361
Hope that helps.
Old Oct 26, 2004 | 02:17 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Those split bolts sound great and look impressive but just imagine how nice its going to be to get the allen bolt turning after they have had a few good years on them and are all heat stressed and coroded. Might work for a show/cruise only car but for a driver I would stay away. There are some new high tech bolts that are presently being used by large truck manufacturers to secure the diesel turbos on as this has been a very big problem for large trucks. These bolts have a gradual step or angle machined into the thread so the load is shared pretty much equally from the top of the thread to the bottom. They have a website but i can't find it. Regardless pretty neat bolts.
Old Oct 26, 2004 | 02:39 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
I wish they fricken made these in Allen wrench bolts. Its impossible to get a 12 point on some of the bolts on my headers.
Old Nov 2, 2004 | 03:05 AM
BRobinson's Avatar
Car: 82 Camaro
Transmission: TH-350
Axle/Gears: 3.08
IIRC, i read somewhere that you could torque the bolts down when the engine is warm, then VERY lightly tack weld the bolts to the header. Lightly, as in just a single very tiny spot. That way the bolt will stay put, but with a die grinder, you can remove enough of the weld in a little under a second to break the weld free if you needed to. That's provided that you're not building a show quality car.
Old Nov 3, 2004 | 11:01 PM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
I found some bolts that i plan on using or if not ill make a similar solution for my header install Summit STG-8906 (mayhave to search using the part number) But that idea seems pretty simple, the "tear" would have to back out putting presure on a primary, making it stay in place, could lathe the botlts for E clips, and then make something similar.
Old Nov 4, 2004 | 12:12 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Try the Stage 8's.
Old Nov 4, 2004 | 01:04 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Found it. the company is called Spiralock. Check it out its pretty cool technology.
http://www.spiralock.com/
Old Nov 4, 2004 | 01:12 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
I'm using allen head bolts from my local hardware store on my SLP Tri-Y's. No problems and they're the only way I can get anything one them for tightening.
Old Nov 4, 2004 | 04:43 PM
Marc 85Z28's Avatar
They DO make bolts with allen heads in them, I have them on my car. Bought them at a local hardware store - a real hardware store, not your local Home Depot or Lowe's.
And about the Stage 8's: they will not work as designed on some headers. They did not work on my Edelbrock's. Apparently the Edelbrocks had small dents in the primaries to clear the bolts. Those dents allowed the crescent shaped washers in the Stage 8 kit to spin.
Old Nov 4, 2004 | 10:46 PM
Rabbitt's Avatar
Car: 1987 Iroc-Z
Engine: 355
Transmission: 700r4 w/ about 7500 miles on rebuild
This is kinda off topic, but a friend of mine (also a thirdgen owner) developed a bad tick in his engine. He thought his cam was goin out so he parked his Camaro early. He went out and checked it like two weeks later.. FIVE HEADER BOLTS HAD FALLEN OUT! Needless to say, after some new bolts, no more tick.
Rabbitt
Old Nov 5, 2004 | 12:14 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You can get them with other shapes besides the crescents.
Old Nov 5, 2004 | 12:47 PM
Marc 85Z28's Avatar
Just checked into that... seems you're right! They were a new product when I bought them, and only style was available. Never bothered to look at them again.
Old Nov 5, 2004 | 03:38 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
One word: Safety Wire
Works great, but kinda PITA to put in the first time.
Old Nov 5, 2004 | 04:30 PM
91Z28-350's Avatar
Mr. Gasket has split locking washers that you can use. I use them and have had no problems so far. They are narrower than washers that you can get at a hardware store so they will fit where header bolts fit.
Old Nov 5, 2004 | 04:57 PM
pasky's Avatar
I was talking about those locker bolts.
Old Nov 8, 2004 | 09:37 PM
RICHRAD's Avatar
Exactly... Using stainless steel lock washers here and no problems so far ...did have to grind a little on a few washers to clear the primaries.
Old Nov 8, 2004 | 11:14 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Stage 8 has the most fool proof design.
Tighten the bolt, put the retainer on, and snap the clip in. It cannot come loose. The 90 Formula uses these, and has never had a blown a gasket since, or had a leak.
As for breslin, they cost 60 or 70 dollars I believe. Their is a point where you are spending to much, and that is crossing it.
This is the kit Stage 8 said would fit my application(82 Trans Am, 305 V-8, LG4)
Summit
Old Nov 8, 2004 | 11:54 PM
Air_Adam's Avatar
Just use safety wire... it works very well (trusted by aircraft industry for millions of years) and its cheap and easy.
Old Nov 9, 2004 | 10:30 PM
SLOWFIVEOH's Avatar
Car: 82' Z28 IROC Clone (SOLD)
Engine: 355
Transmission: Built TH-350
Axle/Gears: 3.73 Moser 12 bolt
In regards to the Allen heads, I have them in the back holes on each side of mine, It makes it a breeze to tighten them up or remove them in those tight places!
hectre13
Dec 11, 2023 08:14 AM
Terrell351
Jun 13, 2021 01:13 PM
1984HO
Mar 19, 2021 11:59 AM
Reddeath210
Oct 6, 2015 08:20 AM
Elliswon
Aug 10, 2015 12:33 PM
