Manual belt tensioner?
Old Jan 15, 2018 | 09:44 AM
Seann's Avatar
Hi,
I'm looking for a manual belt tensioner for the 305 TBI I've got in an '88 Jag XJS....would like to delete the entire a/c bracket, compressor stock tensioner and idler if possible. Wondering if there's something out there before having to make one,
Thanks,
Seann
Old Jan 15, 2018 | 10:52 AM
Drew's Avatar
Re: Manual belt tensioner?
I sit here with my fingers on the home keys, the devil on one shoulder suggesting I give you both barrels for asking such a silly question. While the guy in white with the harp and halo wants me to go easy on you...
A small block Chevy, is a small block Chevy. There are so many original equipment accessory bracket setups, and an entire industry of aftermarket accessory setups, not to mention racing applications, etc. If you can't find something that would work, you're not even trying.
Probably easiest to dump the serpentine setup altogether and just run V-belt brackets.
Old Jan 21, 2018 | 12:52 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Serp. modifications are fun and interesting because there is far more than one way to skin a cat. Keeping what you have and changing belt and tensioner pulley is an option. Sky is the limit with some creativity and the desire to try another setup.
https://www.thirdgen.org/forums/tpi/...without-c.html
And pics in Posts 14 and 42.
https://www.thirdgen.org/forums/exha...ictures-2.html
Tony89GTA
Oct 2, 2017 08:32 AM
1989karr
Dec 19, 2005 01:02 PM
ZRATED
Aug 29, 2001 05:44 PM
91rscruiser
May 30, 2001 07:53 PM
steve88iroc
Oct 29, 2000 09:05 PM
