Crank Pulley Bolt
Crank Pulley Bolt
Whats the size of the center bolt for the crankshaft pulley off of a 1991 firebird 305 motor? Im about to take a road trip to get the serpentine belt system off of a car and need to know what tools to take with me.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Crank Pulley Bolt
Thread Size: 7/16-20 in.
Underhead Length (in): 2.250 in. Balancer bolt size
To get the belt off you need a 1/2 ratchet or breaker bar.
I could be mistaken and it might be 3/8 you can double check the spot is on the tensioner pulley.
Yeah ive been hearing 7/16 and 5/8. Just want to make sure. Also its been a while since ive worked on one of these engines, i will need a powersteering pulley tool to remove the pulley to get to a bolt that is not accessible right? Any other tips?
Engine: Lb9
Transmission: M20
The pulley is held on with 3 bolts. If your trying to remove the harmonic balancer you need a balancer puller.
https://m.ebay.com/itm/46pc-Harmonic...UAAOSwVtZaPLKC
tippyjeep
Mar 10, 2012 09:14 AM
roughskinjrz
Sep 8, 2005 02:19 PM
MrDude_1
Jan 22, 2004 02:11 PM
MrDude_1
Jan 22, 2004 08:24 AM
