Camshaft nose pin length question
Old Feb 3, 2018 | 10:22 AM
Hotrodder's Avatar
Car: 1934 Ford Roadster
Engine: 350 CSB
Hi
I have bought a Howards hydraulic roller camshaft for my Chevy small Block 1 st gen 350 cid L05 engine. Factory roller Block.
The nose pin on the new cam shaft is twice as long as the nose pin on original GM camshaft I took out from the engine.
Is it as simple as just knocking the pin in, until the length is correct?
Old Feb 3, 2018 | 11:58 AM
Drew's Avatar
Re: Camshaft nose pin length question
Pretty much. Might be worth a call to the manufacturer's tech line to be sure. The longer pin is used for the LT1 style engines, something to do with the opti-spark or water pump. Standard process with GM roller cams is to push the pin deeper.
Old Feb 3, 2018 | 01:04 PM
Hotrodder's Avatar
Engine: 350 CSB
Thanks!
Old Feb 4, 2018 | 08:26 PM
cardo0's Avatar
Car: Fourth Gen '94 camaro
Engine: 350 Gen II
Transmission: A4
Without looking it up I recall most users cut the pin down with grinding wheel or hacksaw. Then dress it up with a file.
firebirdjosh
Feb 11, 2006 09:26 AM
Make
Jun 5, 2005 11:41 AM
dtpmike
Jan 7, 2004 08:49 PM
tbfirebird
May 16, 2003 11:59 PM
