Steering Pump Pressure Fitting Size?
Old Feb 4, 2018 | 12:11 PM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Does anyone know what size the pressure line fitting is on the back of the power steering pump?
I'm converting my power steering away from the factory crimped rubber style hose and already have the fittings for the gear. At the steering gear, the pressure side is an M18x1.5 and the return fitting is an M16x1.5
All I need is the correct fitting to go in the back of the pump. It looks rather small. I'd venture to say M14x1.5. Or is it 16 also?
Can anyone confirm?
Old Feb 4, 2018 | 12:18 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Steering Pump Pressure Fitting Size?
I can’t recall the size but they are Saginaw iirc
https://www.summitracing.com/parts/fra-491962-bl
https://www.summitracing.com/parts/fra-491963-bl
http://www.jegs.com/p/JEGS-Performan...81860/10002/-1
Old Feb 17, 2018 | 08:36 AM
Car: 1985 Z28
For anyone wondering, the fitting size on the back of the steering pump ended up being M16x1.5
So for anyone looking to do this conversion:
M18x1.5 - Steering gear pressure port.
M16x1.5 - Steering gear return port
M16x1.5 - Steering pump pressure line fitting
Stevo
Mar 22, 2008 08:33 AM
Confuzed1
Apr 20, 2004 05:52 PM
