What is your PSI set at?
Old Jan 4, 2002 | 07:54 PM
87transam5.7tpi's Avatar
I'm putting on a AFPR next week and was wondering what everybody has there PSI set at? I have a 350 tpi also, I'm doing a cai and headers in the very close future also. and did you notice a big difference by adding a AFPR?
Old Jan 5, 2002 | 03:15 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Best thing to do is monitor the pressure setting with the stock FPR for refernce,set the AFPR the same, then monitor O2 voltage during some runs, increase/decrease as needed.
Old Jan 5, 2002 | 05:22 PM
Damon's Avatar
Your year of TPI uses a stock setting of 43 PSI. Many have found that their cars run a bit quicker with that pushed up to about 45-47 PSI. Stock TPI tuning at WOT is apparently just a smidge on the lean side for best power. Install an aftermarket chip, however, and all that goes out the window.
Best bet is trying different PSI settings at the track ON THE SAME DAY and see what pressure gets you your best time.
No, you won't feel anything in the seat of your pants, usually, unless your backside is precision caibrated like mine.
Old Jan 6, 2002 | 04:20 AM
RedFirebird's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L TPI (L98)
Transmission: 700RJunk
There's some info (dyno-sheets) on this website that actually shows dyno-proven power increases by increasing the fuel pressure. I'll have to find it again but the power increases were something to the tune of like 15-20 horses with the PSI bumped up to around 46-50 psi...
1986Z28OWNER
Dec 13, 2015 10:19 PM
Mutillator
Exterior Parts for Sale
Oct 1, 2015 06:05 PM
355sbcTPI
Aug 19, 2015 04:38 PM
tmellott89
Aug 16, 2015 02:58 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
