Alternator Relocation with AC and AIR delete?
Car: 1989 Iroc-Z Convertible
Axle/Gears: 2.73:1
I am only running an alternator and PS pump. My compressor is in place but I've pulled out most of the AC hardware, and will be swapping in a non-AC heater box and pulling the condensor. Previous owner pulled the AIR system and the pump.
Anyone running a kit similar to this? Just looking to move the alternator over where the AIR pump was to clean up the top of the engine a bit. Will this work on an 89 305 TPI motor (obviously with a custom belt...)??
Photo and link attached.
Thanks.
https://www.summitracing.com/parts/icb-551576
Thanks.
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Alternator Relocation with AC and AIR delete?
Thanks.
Thanks.
Axle/Gears: 2.73:1
Aah. My 89 has a serp belt. I thought I could use a short serpentine belt, and routing the belt under the water pump between the alt and PS pump would get me the proper rotation, or will that not work? If it's not that easy maybe I'll hold off for now.
Axle/Gears: 2.73:1
To be clear, the kit is just the relocation brackets, no pulleys included.
Firebat
Feb 17, 2011 11:53 AM
