SBC 421 dyno results
Old Mar 17, 2018 | 10:15 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Finally got my sbc 421 together and put it on the dyno
Here are the specs:
4.155 bore x 3.875 stroke, 421sbc nitrous motor
12-1 compression, 5.6 dome
Jones cam (lift.699 int, .659 ext) (dur @seat 316int 320ext) (LS112)
AFR245 unported heads with LGM shaft mounts (1.7 int, 1.65 ext rockers)
Edelbrock 2970 ported
Mark Whitner 1050 dominator
Used 1 3/4 dyno headers
With 110 octane fuel made 586 TQ @ 5200 and 686 HP @ 7200 with 34 degrees timing
https://ibb.co/nBMmpc
https://ibb.co/m2Kgpc
With 94 octane pump gas made 567 TQ @ 5400 and 657 HP @ 6500 with 30 degree timing
https://ibb.co/e3A1Nx
Overall really happy!
https://ibb.co/csTP9c
https://ibb.co/eQPLhx
Can't wait to spray a 300hp shot to the engine
I have to install my powerglide 1st before I spray, no way my th350 I have now will hold the power
Old Mar 18, 2018 | 06:24 AM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
Re: SBC 421 dyno results
Very nice. I am curious is the listed lift with or without the 1.7 rockers figured in? In other words is the shown lift with those rockers?
Old Mar 18, 2018 | 09:23 AM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Yes, the lift is shown with the 1.7/1.65 rocker
That is what was advised from LGM and Mike Jones
Old Mar 18, 2018 | 09:37 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Pretty solid for a nitrous motor
Old Mar 18, 2018 | 11:40 AM
cardo0's Avatar
Car: Fourth Gen '94 camaro
Engine: 350 Gen II
Transmission: A4
I like it.
Also proves what Smokey Yunick said: costs 5 times as much to go from 500hp to 570hp with the sbc.
Old Mar 18, 2018 | 11:50 AM
skinny z's Avatar
Nice numbers.
Was that cam spec'd specifically by Jones?
Old Mar 18, 2018 | 11:58 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Originally Posted by cardo0
I like it.
Maybe to 670 lol. Todays head choices are much better than days of old. Up to 600 can be fairly easy to achieve at 400-434”.
Goin over 600 starts getting expensive and need more tricks and special treatment to do imo
Old Mar 18, 2018 | 12:09 PM
cardo0's Avatar
Engine: 350 Gen II
Transmission: A4
I guess I should have qualified that with reliable 570hp. It takes good parts to keep a motor together making that power.
Old Mar 18, 2018 | 09:50 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Originally Posted by skinny z
Nice numbers.
Yes.
I talked to other cam companies as well.
Mike came highly recommended from other guys in the industry.
Plus, I have a 50mm roller cam tunnel in my Motown block, which narrowed down my cam options
Old Mar 18, 2018 | 09:53 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Agreed.
Anything over 600hp meant me getting an aftermarket block, along with nitrous.
I could do it with a stockblock, but not reliably and less longevity
Old Mar 19, 2018 | 06:38 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Nice numbers!! Think there may be a couple more HP in a stepped or larger header?
Old Mar 19, 2018 | 08:39 AM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
On motor, I think the 1 3/4 header is almost maxed out
I have 1 7/8 Ed Quay headers on my car so that'll be better suited once I spray.
But yes, I am curious if a stepped header would help once on spray
Old Mar 19, 2018 | 09:41 PM
HINKSON AUTO's Avatar
What lifters did you use for this build ?
Old Mar 19, 2018 | 10:02 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Crower 66292H
88BlackZ-51
Alternative Port EFI Intakes
91
Jul 18, 2013 10:37 PM
BWilcox
Feb 4, 2013 07:16 AM
BWilcox
26
Jan 27, 2013 02:42 PM
