MAF Operation with 421 CID SBC
Old Jan 25, 2013 | 03:48 PM
BWilcox's Avatar
Car: 87 IROC
Engine: 420 EFI
Transmission: TKO500
Axle/Gears: Moser 9" 3:50
Hi Guys,
I am considering building a fairly large SBC.
Based on Bore and Stroke (DART SHP Block), a 421 looks nice.
I am familure with how to tune the 165 $32B mask. At least for a street cammed 358 CID motor.
After reading a ton of information from this Website, most likely the MAF analog output will max out before the MAF becomes a flow limitation.
What happens to the fueling calculations when the MAF is output is maximized?
Does the ECU go into an N-Alpha Mode?
Are the calculations different for WOT vs. Part Throttle?
My goal is a street car with very limited drag racing duties.
I have not yet put together the complete package, something that runs from 1800 RPM to 6500 RPM seems good to me.
Any help would be greatly apprecited.
Best Regards,
Bruce
Old Jan 25, 2013 | 04:18 PM
Twin_Turbo's Avatar
Re: MAF Operation with 421 CID SBC
Cartridge maf + extended range 33b contact greg carroll
Old Jan 25, 2013 | 07:22 PM
tequilaboy's Avatar
With proper MAF, programming and injectors, the 165 ECM can support up to approx. 1,400 horsepower, so a naturally aspirated 421 is no problem.
A BA5000 sensor or equivalent in a 3.5" tube has enough flow range for about 4600 kg/hr.
If we rescale the airflow calculation into appropriate units, we can easily control fueling for big power.
Here's an example: A convenient mass flow unit for this purpose is myriagrams/hr. WTF is a myriagram? 1 myriagram = 10 kilograms, easy to convert to/from kilograms/hr.
1 myriagram/hr is equivalent to 2.78 gr/sec. As such, 255 myriagrams/hr is equivalent to 708 gm/sec and is sufficient flow to support about 1,000 hp with typical AFR and BSFC values.
Need to support even more power, use slugs/hr instead. 1 slug/hr = 4.05 gm/sec. 255 slugs/hr can support about 1,400 hp.
Since we are working with a mass based system, we can use any unit we want as long as the airflow and product of injector flow rate and base constant units match each other. The days of pegged MAFs and the perceived 255 gm/sec limitation are long gone.
Although these examples are extreme for discussion purposes, they are also realistic. Choice of sensor, housing and scaling should be tailored for the specific application, but the given examples will work for nearly all even if they are overkill.
Tuning is accomplished in the usual manner. Set the AFR target appropriately for the fuel and engine's needs.
Old Jan 25, 2013 | 07:55 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Is there somthing to replace the factory Bosch meter so we can have true 4" cold air intake ductwork ??
Old Jan 25, 2013 | 08:27 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
a cartridge maf can be mounted in a 4" intake the maf scaling on the airflow will need to be changed.
Old Jan 25, 2013 | 10:18 PM
TTOP350's Avatar
A cartrige maf from what?
Old Jan 25, 2013 | 10:39 PM
Engine: Lb9
Transmission: M20
Ls (sorry)
Old Jan 26, 2013 | 03:50 AM
Twin_Turbo's Avatar
Old Jan 26, 2013 | 03:52 AM
Engine: Lb9
Transmission: M20
http://www.ebay.com/itm/LS3-5-Wire-M...2b71a1&vxp=mtr
Old Jan 26, 2013 | 07:41 AM
BWilcox's Avatar
Car: 87 IROC
Engine: 420 EFI
Thanks guys,
If I understand you correctly, we basically take a MAF cartridge that is mountable in a tube to create a custom device.
Some more questions for you:
1.
I should select a MAF cartridge with a max output voltage of 5 Vdc. Correct?
2.
Scale the tube diameter so the MAF output voltage reaches maximum at an airflow that is slightly above the maximum expected airflow from the engine. Maybe a 10% margin?
Is this reasoning correct.
3.
What about the airflow measurement resolution down at idle and low speed conditions?
Are there engine setup issues to note that may exaggerate this potential issue?
4.
What is the best way scale the Injector Constant to work with the custom MAF?
I assume that the MAF cartridge has been characterized with some standard tube size. Assuming laminar flow across the whole diameter, I guess a new Vout cs. Flow Rate may be calculated from the size difference of the standard tube and the tube required for my application?
For example, if I double the Flow Rate through the MAF system at a given Vdc, then I need to set the Injector Constant to 1/2 of the actual value. Correct?
What is the best way to select the proper Injector Size?
Thanks again for the help.
Best Regards,
Bruce
Old Jan 26, 2013 | 01:11 PM
TTOP350's Avatar
This is what I started back in 93ish, it's a 4" pipe. I have had it on the car and running but I need to finish the rest of the cold air setup.
Old Jan 26, 2013 | 03:38 PM
BWilcox's Avatar
Car: 87 IROC
Engine: 420 EFI
Very nice work and picture!
I looked into the BA5000 and the VMP HPX 05+ MAF options. These are 0 to 5 Vdc Ford slot MAF devices. It looks like I would use a 3" tube to support my NA power levels.
The nice thing is a calibration file is included. I can just change the MAF tables in the ECU. Then the Load calculation will be correct and I will not have to modify the spark tables. In addition, I will not have to offset the Injector Constants.
Does anyone have experience with either of these devices?
Best Regards,
Bruce
Old Jan 26, 2013 | 04:11 PM
tequilaboy's Avatar
I have experience with all of the common Ford analog slot style sensors and application of these sensors in tpi cars.
The slot style sensor offers several advantages (in no particular order):
  • Packaging/mounting flexibility
  • Various measurement range options available
  • Reduced flow restriction when used in larger housings
  • Durability
  • Low replacement cost
  • Integrated IAT sensor
  • Sensor availability
  • Directional flow measurement and insensitive to reversion
If you plan to use a 3" tube and tune within the standard flow range for a big inch N/A car, you are missing out on most of the sensor's inherent advantages. I think it is still a worthwile endeavor if used as a stock sensor replacement, but there is much more to be had.
Old Jan 26, 2013 | 04:27 PM
Twin_Turbo's Avatar
Listen to the man ^^ He has helped me tremendously getting mu cartridge maf setup running
Old Jan 26, 2013 | 05:22 PM
TTOP350's Avatar
  • Durability
Sooo If I'm picking up what your throwing down and I think I am. This will be no problem an play nice with factory stuff, It'll get ride of the tempermental Bosch sensor That I have a love/hate relationship with.
What needs to be done with the old MAF power and burnoff circuits/ relays?
Or should I just stepup to the LS computer and harness from EFI Connection?
Old Jan 26, 2013 | 05:25 PM
Twin_Turbo's Avatar
The relays can remain, you will not be using them. You do have to swap 1 wire on the ECM connectior and get an adapter pigtail or make one for the stock maf connector + iat sensor since they both will be gone.
Old Jan 26, 2013 | 06:22 PM
TTOP350's Avatar
Thats not a problem at all, I also have my IAT in my SLP cold air box so I could just add it to the MAF harness like the latemodel cars.
Which wire in the ECM is swapped?
Old Jan 26, 2013 | 06:30 PM
Twin_Turbo's Avatar
MAF signal, green wire
http://www.blowerworks.net/sensor.html
Old Jan 26, 2013 | 06:54 PM
TTOP350's Avatar
Very helpful. It's been a looong time since I looked for anything like this. I can't believe I hadn't seen this stuff B4 Thank you.
Old Jan 26, 2013 | 07:12 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I thought the limitation was code in the actual chip. Hence reasoning for scaling injector constant and modifying the maf tables to cover more range at expense of resolution. Not sure exactly how that works with the code side of things.
I know i made my own 3.5" maf by taking stock maf internals, cutting it out of the factory housing and installing it inside a 3.5" pipe. Worked well but required alot of maf scaling to the point i only used maybe 3 tables out of the 5 or 6 in the 6e bin. I didnt scale the injectors or anything. Just maf scalars and maf table mods. Car didnt seem to gain anything but ran just as good even with reduced resolution
Old Jan 26, 2013 | 08:27 PM
tequilaboy's Avatar
A couple comments regarding resolution:
We are only limited by the ecm's 8 bit A/D converter. Each A/D count represents 0.02 volts or 20 mV. 255 counts = 5.12 volts. From the Motorola reference manual (hc11rmr3):
"When V
RH – VRL = 5.12 V, 1 LSB corresponds to 20 mV of input voltage."
Since the MAF transfer functions are parabolic, the resolution (in terms of flow per A/D count) varies continuously as a function of flow and voltage. At low flow rates, the delta flow per A/D count is small, which allows for sensitve measurement and high resolution. At high flow rates, just the opposite.
Measurement error due to the 8 bit A/D converter's limitations has more effect at high flow, so a slightly richer target AFR can compensate for any under reported airflow between A/D counts at high flow. Deeper analysis suggests the opposite effect with respect to total flow on a percentage basis. As flow increases towards the maximum, the error due to resolution limitations approaches 1%. Idle is worst case with error on the order of 3-5% of flow. This trend is the same with the stock MAF.
Here are a couple of example transfer functions for the BA5000 sensor in different tubes to illustrate (try and imagine these curves with 255 points to get an idea of what the ecm sees):
The blue curve would be well suited for the myrigram/hr example (255 myriagrams/hr = 2550 kg/hr), and the pink curve would be a good fit for the slugs/hr example.
Regarding signal resolution, the MAF display flow signal is a 16 bit value, so signal resolution is 0.0039 units of flow per bit. 0.0039 Myriagrams/hr is equivalent to 0.0108 gm/sec or ~0.0143 hp. 0.0039 Slugs/hr is equivalent to 0.0158 gm/sec or ~0.022 hp. Signal resolution is sensitive enough even at the extremes.
If we use a transfer function that fits the 255 myriagram/hr unit example which is suitable for 1,000 hp, in the idle region at around 9 gm/sec flow, a 20 mv change is approx. 0.46 gm/sec. This is the working resolution at low air flow. Using the same example at the top of the scale at 700 gm/sec, a 20 mv change is approx 7.5 gm/sec or roughly 1% of the full scale flow.
It should be clear that the 20 mv A/D resolution is the primary limitation. Considering the oscillatory nature of closed loop control, this is still sensitive enough for good idle control and accuracy as power increases.
Here's a cool screenshot (from a dynojet pull):
This particular run made 480 rwhp with a partially heat soaked intercooler as shown by the MAF Air Temp signal. Based upon the MAF voltage and bpw readings this was only making use of half the tune's capacity at the time. I need a bigger blower.
Similar shot (on track this time). Slow pass w-120 trap speed. Interesting to note the bpw is the same (out of coincidence). Different day, tuning, target, rpm etc.
Old Jan 26, 2013 | 09:57 PM
TTOP350's Avatar
My motor doesn't start pulling until 3,500-4,000rpm an pulls till 7,500-8k rpm fairly easy.
I can't wait to finish a few things and get a real tune instead of just the stock chip in it.
It should sing fairly well.
Old Jan 27, 2013 | 09:06 AM
BWilcox's Avatar
Car: 87 IROC
Engine: 420 EFI
Thanks Guys,
Great information here.
However, somewhat confused??
I found a connector schematic for the FORD MAF/IAC.
Pin 1 : GY/RD : IAT Ground.
Pin 2 : RD : +12 Vdc Switched Power.
Pin 3 : BLK : MAF Ground.
Pin 4 : TN/LB : MAF Return.
Pin 5 : LB/RD : MAF Analog Output : 0 Vdc to 5 Vdc.
Pin 6 : GY : IAT
What about the GM MAF from Blowerworks? Is this a Analog Output device? Or is it a Frequency Output device with a convertor to analog?
Does anyone have a Connector Schematic for the GM MAF?
Thanks,
Bruce
PS. Still thinking about the MAF tube diameter. More comments/questions later.
Old Jan 27, 2013 | 09:18 AM
Engine: Lb9
Transmission: M20
LS3-7
http://www.mouser.com/ProductDetail/...HFoXU0p1BTU%3d
Old Jan 27, 2013 | 11:27 AM
tequilaboy's Avatar
For clarity, everything I've posted on this topic refers to experience with the Blowerworks MAF and related products along with the general technology involved.
In this context, we've been talking about an analog sensor with Ford style connector. An adaptor harness is available from Blowerworks to allow simple plug-in installation to the factory harness mating connector.
Best bet is to contact Blowerworks.
Frequency based GM MAFs could be made to work, but this would tend to increase both the cost and complexity since a translator would be required to adapt the signal. Somewhat unknown territory.
Old Jan 27, 2013 | 12:38 PM
BWilcox's Avatar
Car: 87 IROC
Engine: 420 EFI
Hi Guys,
Thanks again for the information.
So far, it looks like I need to move forward with the Ford based Slot MAF option as opposed to the GM based Slot style MAF. Much easier to work with an analog output!
I looked at the Blowerworks Website. Here is what I found for the L98 MAF.
Exact "Physical" Replacement MAF Sensor for Original Bosch L98 Unit
Price as shown above with "Bosch" OEM 'clip adaptors'
for L98 'Y' & 'F' Body vehicles: $399.00.
Description: Thin Film RTD Sensor similiar to the LS1/LS7 etc. MAF sensor.
Indestructible and can accomodate 600 RWHP (500 gms/sec).
Installation does require a new .bin file that we sell as follows:
Bone stock replacement bin: $99.00 with purchase of MAF sensor assembly. Stand alone price $199.00
SuperCharged bin with PulseWidth Cap Fix: $199.00
What confused me was the LS1/LS7 statement?
My guess is they are using either the SCT BA5000 Slot MAF or the HPX Slot MAF with a custom enclosure. Either one is analog.
I ran some simple 1st order calculations:
CFM=[ (CID*RPM)/3456 ]*VE
For a 421 @ 6500 @ 0.9, the CFM = ~ 713.
The equivalent flow in gms/sec = ~ 404.
It appears like the Blowerworks Bosch MAF replacement would work for my application? Not sure on the enclosure size?
What is your recommendation on the enclosure size?
Best Regards,
Bruce
Old Jan 27, 2013 | 02:42 PM
BWilcox's Avatar
Car: 87 IROC
Engine: 420 EFI
Hi Guys,
I downloaded the Blowerworks L98 MAF document.
What is the purpose of the B12 (original MAF Input) to D8 (new MAF Input) swap?
Is the 1K pull-up resistor (on B12) too strong for the FORD MAF to work against?
What is D8? My guess is a spare analog input port on the ECU.
The code change is to re-map the MAF input port. Correct?
Best Regards,
Bruce
69GTOby
Apr 18, 2016 02:34 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
92rsvortec350
19
Oct 9, 2015 09:39 AM
Damon
Sep 26, 2015 04:29 PM
IROCZ1989
Sep 4, 2015 11:54 AM
