How to test ignition coil?
Old Mar 22, 2018 | 09:43 AM
michael's Avatar
Car: 1991 Formula
Engine: 6.2 383 TPIS Miniram
Axle/Gears: Moser 9" 4.11
We picked up some spare parts the previous owner of our bird found in his garage a bit back. Two of which are ignition coils. I obviously have no need to hang onto non working parts.
At one point and time I had a printout of what terminals to check and what the readings should be but can't seem to find it anywhere. Is there write up somewhere on what terminals to check with a volt meter to find out if these are good or just trash?
Old Mar 22, 2018 | 10:04 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: How to test ignition coil?
Devorced hei coil ?
Old Mar 22, 2018 | 10:07 AM
michael's Avatar
Car: 1991 Formula
Not sure what you mean but it looks like that one with the 4 terminals and the one plug wire terminal. Does test one get tested against the magnet since that's what it's pointing to? I'll have to stick paper clips in the terminals because my lead points are too fat to fit lol.
Old Mar 22, 2018 | 11:33 AM
Engine: Lb9
Transmission: M20
Test 1 looks like to ground or the case of the coil.
There is another thread in the tbi section where a member states test two is incorrect. You might want to search that or just pulg in the coil on your car and test it that way.
Old Mar 22, 2018 | 11:39 AM
Engine: Lb9
Transmission: M20
https://www.thirdgen.org/forums/tbi/...fuel-pump.html
XxXChrisGXxX
Jul 30, 2008 07:29 PM
Akshay
Apr 29, 2002 10:16 AM
Akshay
Apr 21, 2002 02:43 AM
jfox55
Apr 8, 2002 05:49 PM
ViciousZ
Oct 9, 2001 10:26 PM
