pressure testing fuel tank?
Old Mar 29, 2018 | 01:33 AM
racerx520's Avatar
hey folks, does anyone have any thoughts on how to pressure test the fuel tank (preferably a kit i can purchase)? I had repaired the tank filler neck about a decade ago, but had to drop it to do the fuel pump recently. I am unsure if i broke the soldering on the tank or not, and want to test the tank before dropping it again since the car stinks up the garage of raw fuel if i fill the tank above 3/4 full.
thanks in advance!
Old Mar 29, 2018 | 08:41 AM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Re: pressure testing fuel tank?
Why waste time testing it if you already know it is leaking?
The tank has a pressure relief valve (which oten is not functional due to age).
Consider cleaning the pressure relief valve as a first priority.
Then drop the tank if its still stinking up the place.
Old Mar 29, 2018 | 09:20 AM
racerx520's Avatar
is that the white valve near the rear axle? and i'm not certain its leaking from the gas tank. But i have had the filler neck repaired before, so i'm not sure if i broke it again. Thank you.
Old Mar 29, 2018 | 08:28 PM
W.E.G.'s Avatar
Engine: V6 2.8
Yes.
Old Mar 29, 2018 | 08:31 PM
W.E.G.'s Avatar
Engine: V6 2.8
If you have a small crack at the filler-neck/tank junction, don't be too proud to apply a generous JB-Weld patch on the leaking area.
388iroc
Southern California Area
May 1, 2002 07:42 PM
Blue502
Pacific Northwest Region
16
Aug 24, 2001 06:37 PM
