MAF or Speed ?
Old Apr 8, 2018 | 03:47 AM
tripple D's Avatar
Car: 1975 HJ HOLDEN
Engine: TPI 305
Transmission: th700
Axle/Gears: 3.9
MAF or Speed ?
I have a TPI 305 and a TH700 in a 1975 model car (see my profile)
Would like to know, is a MAF or a Speed a better system ?
I have to buy a new Wiring Harness, this car will be driven regular, and there are no upgrades to the engine bar a set of custom headers.
AND Where would you recommend to get one ?
As im in Australia.
Thank you
Attached Thumbnails MAF or Speed ?-4-mine-now.-tpi
Old Apr 8, 2018 | 06:50 AM
vinny R's Avatar
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
Re: MAF or Speed ?
As im in Australia.
Thank you
Speed density, it is more reliable.
Go to the parts for sale forum here, There is a guy in Pennsylvania selling TPI stuff and he has a couple harnesses for sale right now.
Old Apr 8, 2018 | 07:57 AM
tripple D's Avatar
Car: 1975 HJ HOLDEN
Engine: TPI 305
Transmission: th700
Axle/Gears: 3.9
up grade
greetings all from the land down under of Australia, please don't hold this against me ha ha. I new hear so hear goes. I have a 1975 HJ Holden primer with a TPI 305 th700 and a 4pin LSD 3.9 diff. we have deleted the smog gear and run headers now, the th700 has a stage 2 shift kit and a 3500 stall. as you can image its a little different in a older car over hear and gets a few looks of surprise.
my question is am i able to do a crate motor swap to a 300hp 350 ? Its a more common engine hear, im not looking for a race or a drag car but a nice cruise machine. any help would be much appreciate, the TPI is not a common swap in Australia. I love the look of the TPI.
thank you
Old Apr 8, 2018 | 12:20 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: MAF or Speed ?
Contact John, he has memcals ( computer chips) for a 350 swap.
https://m.ebay.com.au/itm/CHEV-CORVE...MAAOSwT6pVjJ5g
Old Apr 8, 2018 | 12:23 PM
Engine: Lb9
Transmission: M20
Re: MAF or Speed ?
Looks like you might be running the 808 ecm ( mounted on the bulk head ?).a Holden speed density and maf ecm depending on the code being used.
Old Apr 8, 2018 | 12:34 PM
Engine: Lb9
Transmission: M20
Re: MAF or Speed ?
You might be able to locate a local tuner here
https://pcmhacking.net/forums/
I’m not sure this thread might get locked it’s posted in the wrong section.
Grumpy
24
Jun 7, 2002 10:15 AM
Jon88GTA
Mar 20, 2002 02:20 PM
Reno
Sep 1, 2001 10:34 AM
