How Quickly Can a Fuel Filter Get CLogged Up?
Old Apr 10, 2018 | 09:12 AM
GTA88's Avatar
88 GTA 5.7 liter
I know, depends on how dirty the gas is and whether there is rust in the tank.
But I want to ask anyway. I changed the filter back in 1998 when I bought the car. It had 115,000 miles on it then. Now has 167,000 miles. So 20 years and 52,000 miles. Yeah I know, just change it, right?
The filters on these cars are so big it's hard to imagine them ever getting clogged, but I guess they could.
Anybody ever find their fuel filter actually clogged, and what from? Rust? Dirty gas from a sketchy gas station?
Did you saw open the old filter to look inside?
Thanks! Just curious.
I'm having an on again, off again bogging problem, which I think MIGHT be due to a clogged fuel filter, among a million other things.
Old Apr 10, 2018 | 10:22 AM
Drew's Avatar
Re: How Quickly Can a Fuel Filter Get CLogged Up?
Can't see much of serious contamination making it past the filter sock on the pump. The inline filter is one of those things, I replace them like I change other fluids, once in a blue moon, just because preventive maintenance. Never changed one and actually noticed any improvement.
So tell me about your fuel injectors?
Old Apr 10, 2018 | 11:42 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I can't give you a definitive answer, but I had a low mile filter in my car and my friend, who is a mechanic, said it should be changed. Not that he is the end all expert, but he tried blowing through it and said it felt too restrictive. Not that it is your problem, but it can't hurt to just change it.
Old Apr 10, 2018 | 05:05 PM
You already answered your own question.
Yes they clog. Yes people have to change them out all the time. Yes yours could be clogged too.
Past that, just swap it out and see if anything changes. Even if it doesn't, ... hey, at least you know your fuel filter is now not clogged.
I'm not one to advise just randomly swapping parts, mostly; but filters DEFINITELY belong in the category of "when in doubt, swap it out". Say that about 4 or 5 times until it sinks in.
Old Apr 10, 2018 | 08:25 PM
zed-028's Avatar
Car: 1987 Z28 Camaro
Engine: 305 LG4 4bbl
Transmission: TH700R4
for such a cheap and easy item to replace, sofa is on the money
Old Apr 10, 2018 | 08:59 PM
GTA88's Avatar
The fuel injectors are whatever was in the car when I bought it, so I assume they are the originals.
Old Apr 10, 2018 | 09:08 PM
88IROCvertZ's Avatar
Car: 1988 IROC Z Convertible
Engine: 305 TPI (LB9)
Transmission: 700 R4
Axle/Gears: G80 GU2
A buddy of mine had a firebird (87 I believe). He ran out of gas and after he got new gas put in it, it wouldn’t start.. first thing we did was change the fuel filter and it started right up..
I changed mine in my 87 every 40k miles or something like that.. never noticed a difference from doing it..
Old Apr 11, 2018 | 08:05 PM
zed-028's Avatar
we usually kill pumps and clog filters at the end of winter/start of summer here in Australia. Over winter the sellers put some waxy crap into the underground tanks to prevent it from freezing which ends up in your tank, as summer hits all that crap melts and goes through your fuel system.
Guaranteed it will always happen just after you fill up
Animus
May 13, 2006 08:35 PM
Sickness91Z28
Apr 10, 2005 09:38 PM
screaminformula
Aug 16, 2004 07:58 PM
IceBlue91z28
Nov 29, 2002 02:43 PM
GTA88
Jun 21, 2001 12:54 PM
