will this work?????
Old Jan 5, 2002 | 05:02 PM
MCMLXI's Avatar
will this work?????
I dont know much about rear ends but i was wondering if this might work in my 91 Z28 3:42 ratio rear differential from a 1997 Pontiac Trans Am. The rear has positraction and rear disc brakes. with rear rotors and calipers.
Old Jan 5, 2002 | 06:03 PM
ede's Avatar
ede
the whole thing will bolt right up or you can just swap carriers and put your ring gear on the 4th gen carrier. make sure the splines are the same. or you can swap carriers and change you pinion.
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
