Headlight gear 88 trans am
Old Apr 23, 2018 | 12:50 PM
AJD88TA's Avatar
Engine: 5.0L 305TBI
I have a 88 trans am but my headlight on my passenger side will not go up, i know that my gear is stripped and my motor does work because when you turn the lights on, the tuning **** spins freely, my question is how do i get the headlight out even though it wont go up. i already have a rebuild kit for it as well with the gear and bushings. Thanks
Old Apr 24, 2018 | 02:29 AM
Drew's Avatar
Re: Headlight gear 88 trans am
Lift and turn? When the motors are toast, you can usually lift the headlight doors. Nothing else, remove the two brackets from the top of the rad support, and the two from under the front bumper, and the entire headlight assembly lifts out.
Old Apr 24, 2018 | 08:27 AM
AJD88TA's Avatar
Engine: 5.0L 305TBI
my headlight motor is fine, it's just the gear that stripped out inside so it won't allow me to lift up on the headlight
Old Apr 24, 2018 | 03:58 PM
nova983's Avatar
Car: 1988 Trans Am GTA
Axle/Gears: 3.70
You can spin the **** on top of the motor while lifting on it. It probably is just needs the rod bumped to unlock and then it should lift right up if the gear is striped.
Old Apr 24, 2018 | 07:18 PM
AJD88TA's Avatar
Engine: 5.0L 305TBI
The **** just spins freely, i cant get it open. i dont want to yank on it super hard, it is 30 years old
C4 Suke
Jun 27, 2004 11:45 PM
Slow Iroc
Aug 16, 2001 01:50 PM
Groove Merchant
Jul 27, 2000 03:10 PM
