Help decoding an engine
Old May 8, 2018 | 01:12 PM
onnik's Avatar
I am french, excuse me for my aproximatif English
The engine and on my corvette of 1973. I search the origin, can you help me?
small block 350ci 15R525848 T0122CMJ
Thank you
Old May 8, 2018 | 01:19 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Help decoding an engine
The block number behind the drivers side head will tell you if it’s a 305 or 350.
http://www.nastyz28.com/chevy-engine-code-stampings.php
Old May 8, 2018 | 04:06 PM
onnik's Avatar
The engine is a 350ci equippedwith a carburettor 625 carter
Old May 8, 2018 | 09:17 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
How do you know it's a 350? It looks identical to a 305 when looking at it like that.
Normally the suffix code can tell what block it is however your CMJ can be a 305 or a 350.
In 1980, it was a 305. In 1974, it was a 350 police special rated at 160hp. In 1975 it was a federal rated 145hp.
You're going to need to get a casting number off the block to better pinpoint it's origin. What it originally was doesn't mean a whole lot.
15R525848 = Last part of VIN from original vehicle.
T0122 = Tonawanda engine plant January 22.
Old May 9, 2018 | 12:42 AM
onnik's Avatar
The casting number is 3970014
160hp is little
QwkTrip
Jun 3, 2026 04:10 PM
iroc-yow
Apr 5, 2018 12:53 PM
LDuncan
Feb 25, 2018 04:35 PM
Trans_AM_88
Jul 14, 2003 09:01 AM
TK87TA
Dec 18, 2000 01:27 PM
