What Hardware for airbox???
Old May 20, 2018 | 06:47 PM
Abubaca's Avatar
Guys, what hardware/fasteners go here in these holes? I've got the filters in the lower box, and the upper box sealed to the lower via the spring loaded twist clips, but I haven't had the whole assembly fastened to the nose and radiator support in 15 years!!!!!!! ....finally getting around to fixing all the little stuff. Anyhow, I know that along the radiator support it uses push pins/clips which I have, but it looks like the front 5 along the front edge, and 1 each on the left and right use screws. Anyone have a pic? I did dig out one the female body clips attached to the nose, so I can figure out the thread, but what does the actual fastener look like?
Old May 20, 2018 | 07:45 PM
Drew's Avatar
Re: What Hardware for airbox???
7mm hex screws with floating washer. Don't see a pt# listed anywhere.
Old May 21, 2018 | 07:46 AM
Yup; just yerbasic #8 screw, about ¾" long, 7mm hex head, large floating washer. There's A BUNCH of them all around there you can look at to match against.
Old May 21, 2018 | 10:06 AM
Abubaca's Avatar
Cool, thanks guys. I thought I could probably figure it out, but.....also knew someone here would know.
Old May 21, 2018 | 10:14 AM
SirReveller's Avatar
Car: '89 'ROC
Engine: 5.7L
Love the graphic there!
Old May 23, 2018 | 08:05 PM
Abubaca's Avatar
Thanks! -although now I need to find somewhere to put it! ....switched to an open element. May build a cold air, but so far so good. Just couldn't breathe through the factory air box.
W.E.G.
Apr 28, 2018 07:24 AM
Stangski09
Jun 20, 2010 11:31 PM
cbpldc
May 14, 2001 03:12 PM
theformula
Aftermarket Product Review
Oct 10, 2000 09:49 PM
