Top end kit
Old May 24, 2018 | 09:25 PM
seiplentz's Avatar
Car: 85 Z28
Engine: GMPP 350 HSR
Axle/Gears: 4th gen 3.42 Posi LS1
Top end kit
Looking at buying this top end kit from summit.
https://www.summitracing.com/parts/t...et?prefilter=1
Will it work well with my HSR? I have a goodwrench 350 4 bolt main motor. I'm really interested in the whole kit because its all matched to work well together.
Old May 25, 2018 | 09:52 AM
Re: Top end kit
That will depend on your tuning skillz. Those will DEFINITELY be called upon. At least it'll all bolt up; but as far as, will you be happy with it? is it the best possible path? is it "matched" to EFI? those are questions of a whole other kind, that I can't answer.
Old May 25, 2018 | 10:45 AM
ULTM8Z's Avatar
Re: Top end kit
Plan on bigger injectors (if yours are currently stock), higher ouptput fuel pump (again, if yours is currently stock).
Sofakingdom is correct... plan on some major re-tuning as well. If you plan to do that yourself, do a lot of reading ahead of time and plan on getting a WB O2 sensor.
Old May 25, 2018 | 02:39 PM
seiplentz's Avatar
Car: 85 Z28
Re: Top end kit
Ok Ill add some more details about what I have already. holley 58mm TB Commander 950 ecm with an innovate WB already. Oh and 24lb injectors. I have a newer pump but its nothing special. also I have 700r4 and 3k convertor to go in. I am not that educated with tuning. Ive messed around with the 950 a bit but dont fully understand it all. The big question is the cam to much for EFI? will it run with a base tune? Is the kit worth it?
I'm not a super educated engine builder so I figured a kit like this puts a matched set of performance together for you.
There are a few good tuning shops around I can get it protuned. Which I might if its that ruff.
mcbchild
Jun 8, 2008 06:53 PM
91greenbird
Jan 27, 2006 08:19 AM
bbigbrn612
Fabrication
Oct 12, 2004 02:32 PM
