Is this a non-standard fuel pump relay wiring?
My car is an 88 GTA with 5.7 liter TPI.
My fuel pump relay has 5 wires, in order, tan/white, black, green/white, orange, and orange. Isn't there supposed to be a red wire somewhere?
My Chilton's manual says it should have one red wire and one orange wire.
Also, when I test the voltage there, what wire should I probe?
I was thinking of probing either one of the orange wires, with engine running, relay still connected together, and expecting to see 12 volts.
Thanks!
Thanks!
Car: check
Engine: check
Transmission: check
Re: Is this a non-standard fuel pump relay wiring?
Looks OK (see diagram). Probe the orange wire in location E, that goes to the battery.
RBob.
RBob.
