TPS
Old Jun 22, 2018 | 03:10 PM
79Daytona's Avatar
TPS
Hey guys well I'm back working on my 92 Z28 Camaro 5.7 TPI I just installed a new TPS now the old one may have been fine but the guy I got the car from mess with it so better safe than sorry . So I was wondering what do you set the multmetter on to adjust it and what should it read.
Old Jun 22, 2018 | 03:12 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: TPS
Tpi .67-.76 If it has elongated holes for adjustment. Stock replacement should have elongated holes but 85-89 elongated tps are cheaper for some reason.
The vom gets set to dcv . The black and blue wires are the wires to test. Greay is the 5v reference.
Old Jun 22, 2018 | 03:29 PM
79Daytona's Avatar
Re: TPS
Thanks Tuned Performance. The TPS I got doesn't have elongated hole so should I try and fine one with elongated holes.
Old Jun 22, 2018 | 03:36 PM
Engine: Lb9
Transmission: M20
Re: TPS
Unless you want to save alittle money. Slotted hole ones are $20-28 at RockAuto . Non elongated ones are $50-60 .
Old Jun 22, 2018 | 03:52 PM
79Daytona's Avatar
Re: TPS
That's cool I'll go with what I got but thanks for the info it will save me a little money next time . Oyeah I saw a video of some guy setting the TPS to .54 dose that sound right to you.
Thanks again.
Old Jun 22, 2018 | 03:54 PM
Engine: Lb9
Transmission: M20
Re: TPS
.54 is for tpi maf , on speed density the ecm looks at the value as throttle blades set to idle and it might work at .54 but the spec is alittle higher.
Old Jun 22, 2018 | 03:56 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Re: TPS
90-92 tps are not adjustable.
Old Jun 22, 2018 | 04:07 PM
79Daytona's Avatar
Re: TPS
Cool thanks for the info again Tealman92 I thought you adjusted by turning the screw on the other side of the TPS was I told wrong.
Old Jun 22, 2018 | 04:46 PM
Engine: Lb9
Transmission: M20
Re: TPS
The screw on the opposite side (drivers side) if for the minimum air speed.
Old Jun 22, 2018 | 04:58 PM
79Daytona's Avatar
Re: TPS
O ok well I guess i don't need to adjust it
Old Jun 22, 2018 | 05:13 PM
Engine: Lb9
Transmission: M20
Re: TPS
Unless your having idle issues, to high or to low you don’t need to adjust it.
There is a procedure for adjustment.
Old Jun 22, 2018 | 05:53 PM
79Daytona's Avatar
Re: TPS
Well I don't have an idle issue per say but at times I seem to have I guess what you would call a flat spot in acceleration when taking off from time to time and sometimes in stop and go traffic the car idles a little rough. So I though the TPS might need adjusting.
Old Jun 22, 2018 | 07:37 PM
79Daytona's Avatar
Re: TPS
Well I search the forum on how to set the minimum air and I can't make heads or tails out of it so call me dumb. I know I'm an old dude and this is the first TPI motor I've worked on I'm so use to working on carbs . So if anyone can help me out I would owe you one.
Old Jun 22, 2018 | 08:22 PM
Engine: Lb9
Transmission: M20
Re: TPS
I’m not sure the source of your flat spot is fueling or spark. I would guess a fueling issue.
To set the minimum air speed.
Jumper the aldl connected a to b.
This connector is at the drivers side knee area.
Turn the key to the on position.
Unplug the iac valve connector , it’s the large 4 connector bye the tps.
Start the engine and set the rpm to 650 rpm. This is all done with a warm engine. Reconnect the iac connector and your done.
If you have a scanner you can set the iac steps to 20-25 steps at idle.
Old Jun 22, 2018 | 08:42 PM
79Daytona's Avatar
Re: TPS
Thanks for the info again. I 've put a new 14 gal gas tank and sending unit and fuel pump as well oyeah and a fuel pressure regulator . It reads 44 psi when primed and 37 psi when running. so I don't know I thought maybe the TPS or the minimum air might be my problem . Well thanks again for your help.
beamar
Dec 24, 2002 12:25 PM
Slow89Iroc-Z
Jul 5, 2002 01:40 AM
MikeT 88IROC350
Mar 16, 2002 04:08 PM
