Fuel pump relay question
Old Jul 9, 2018 | 05:19 PM
Thirdvert89's Avatar
I’ve checked fuel pump fuse it’s good not heating pump turn on when I turn key was told relay could be bad or pump just needs replacing. Before I do the replacing how do I determine if relay is bad
Old Jul 9, 2018 | 05:29 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Fuel pump relay question
Old Jul 9, 2018 | 05:31 PM
Engine: Lb9
Transmission: M20
The ecm sends voltage on the green and white stripe wire for 2 seconds.
You can check this power at the relay and on the pump grey wire. The relay ground cavity f , power to the relay secondary winding cavity a bat + . And cavity e grey wire to the pump. Or depending on your relay type you can switch a fan relay with the pump relay to see if it works. If your not hearing the pump jumper the ops and check for power on the grey wire at the fuel tank connector. If you have power and a good ground the pump is bad.
Old Jul 9, 2018 | 10:34 PM
Thank you tuned performance for your help
Bobby_80s
Jul 13, 2012 01:36 AM
RMK
Jan 10, 2009 03:56 AM
makinemtap
Jan 30, 2002 01:09 AM
Iroc_Z28
Jan 28, 2002 05:41 AM
