Starter replace w/ hedman shorties - need to drop headers?
Old Jul 11, 2018 | 08:48 AM
89RedFormula's Avatar
Car: 1989 Pontiac Firebird Formula
Engine: 305 TBI (stock)
Transmission: T5 (Converted May 2025)
Axle/Gears: 2.73, non-posi drum
Hi guys,
My car is an 88 305 TBI automatic and has hedman shorties.
The headers are causing starter heat soak issues on hot days (leaving me unpredictably stranded) and the car is my daily driver, so I wanna replace the starter and solenoid and then wrap the starter with thermal wrap.
I have no idea how old the starter and solenoid are, so replacement with new seems smart from a reliability standpoint.
My question: will the passenger header need to be dropped or is there sufficient clearance to remove the starter without doing so?
Rob
Old Jul 11, 2018 | 10:52 AM
Go Blue's Avatar
Re: Starter replace w/ hedman shorties - need to drop headers?
I just put shorties into my 88 IROC 5.7L and I didn't have to take it out when I put them in, but I'm not sure if you'd have to remove them to get it out. I'd be interested in learning that info. When I did starters on my 3 other 88-89 305 TBI Firebirds, the trick that I did learn was to point the nose of it up in the air and then bring it straight down. I recommend not being underneath the starter when you start this in case it slips. It's a heavy little bastard!
Old Jul 11, 2018 | 04:10 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
yes it will come out.
but DO NOT reinstall the stock starter. Pick up a stock starter for a 96 Z28. It's smaller, lighter and a more efficient design that is much more resistant to heat soak.
the easier install is worth the price of admission alone.
Old Jul 13, 2018 | 01:59 PM
Unfortunately I already had a stock ACDelco starter for my car sent. Not worth it to me to ship it back to get the newer type. I crawled around underneath and it looks simple - drop the Y and call it a day.
Old Jul 13, 2018 | 02:10 PM
naf's Avatar
naf
try loosening the collector bolts to let the y drop down a half an inch or so first. might get lucky.
Old Jul 13, 2018 | 02:33 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
c4mo
Mar 31, 2014 02:35 PM
dhirocz
May 19, 2010 10:33 PM
Sonix
May 24, 2006 10:15 PM
12SecondTA
Apr 7, 2006 02:14 AM
