Losing coolant and just replaced heating core
I just replaced the heating core on my 2008 Impala and had to add coolant a week later. Then my transmission went out and had to add coolant again. My floorboard isn't wet and there are no puddles under my car. My oil looks clean and I don't see anything coming/running from the pump. My car isn't overheating either. Where the hell is my coolant going?!
Re: Losing coolant and just replaced heating core
As such , your post and question are off topic for this site and may well get locked or deleted .
Now , since you asked nice (Loved the "Where the Hell is my coolant going ?!")
I'll tell you this ;If you see no coolant hitting the ground to make a leak easy to spot , the proper diagnosis will come from a "cooling system pressure check" .
Best of luck with your findings .... Joined: Apr 2009
Car: 1987 IROC-Z
Engine: L98 5.7L
Transmission: MD8 700R4
Axle/Gears: G80 GW6 3.27:1
It could also just be the coolant system burping some air. Keep an eye on your temp gauge and drive it for a few days checking the coolant overflow bottle before you start each morning.
..... And the worst case scenario is that you have a blown head gasket.
That would mean that your coolant is leaking into a cylinder and is being burned in the engine.
I'm not saying this is your problem, just a possibility.
As said above, have a pressure test done. Good luck.
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
lol i always look forward to seeing a non Fbody/TPI/TBI etc post here at least once a week. I'm waiting for the day when an electric bicycle needs diagnosis.
