1987 2.8 throttle rpm issue
Old Jul 26, 2018 | 08:44 PM
jaystoy's Avatar
Need some help. My son's 2.8 has developed two issues. It's a stick car. It has developed a slight intermittent misfire, but tonight after starting it cold, if you tap the gas pedal, the idle hangs a bit and drops down slowly. Then twice, I would tap the pedal and the rpm would just race out of control, had to turn the motor off so it would not throw a piston. What could cause this? Throttle linkage if free and unstuck.
Old Jul 27, 2018 | 08:24 AM
OrangeBird's Avatar
Car: 1989 Firebird
Re: 1987 2.8 throttle rpm issue
If your 101 % certain the throttle plate in the throttle body is not hanging open , your very next check/procedure will be to clean and check the operation of the "I.A.C." , the Idle Air Control valve . A search of this site will describe the functioning/cleaning of the IAC and after you do that remember that the "IAC Relearn" procedure is valid for the 3.1 engine only , your 2.8 needing only for it to be cleaned (as well as the throttle body passages where it screws in) and to be reinstalled as the procedure you'll find in a search states (the pintle must be fully retracted into the IAC valve body upon reinstallation) ...
dimented24x7
Carburetors
Apr 24, 2007 12:55 PM
madmachine
Carburetors
Feb 12, 2002 07:02 AM
Twilightoptics
Jun 25, 2001 01:51 PM
stallone
Jun 22, 2001 11:07 AM
gruveb
Feb 11, 2001 11:09 AM
