Whats size tap for head bolts
Old Jan 6, 2002 | 10:01 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I am cleaning the holes before the new heads. What size tap?
Old Jan 6, 2002 | 11:09 PM
88WS6TA's Avatar
IIRC it is a 7/16-14. I would not use a tap but instead pick up a thread chase available at summit or a local tool supply. A chase is not as sharp and is easy to get to start in the threaded hole.
Old Jan 7, 2002 | 05:38 AM
ede's Avatar
ede
yep 7/16-14 i use a tap on the block but a thread chaser might be better. i use a wire brush on my grinder to clean up bolts but the sealer on head bolts is hard to get off so i use a thread chaser on them first.
toronto formula
Nov 10, 2015 06:17 AM
355tpipickup
Aug 25, 2015 12:54 AM
86White_T/A305
Aug 17, 2015 12:16 AM
knight72
Aug 10, 2015 09:32 PM
