L98 engine mounts
Old Aug 23, 2018 | 05:51 PM
Galaxie500XL's Avatar
Car: 1988 IROC-Z
Transmission: T56 swap ongoing
Axle/Gears: 2.77 9-bolt Posi
L98 engine mounts
Got my AC/Deacon engine mounts...these things are ridiculous in cost, and I was very disappointed to see “made in China” on the boxes.
Still, they look okay, hopefully they’re higher quality than the no-name parts store mounts.
But I noticed today that the driver side mount bolts on the crossmember are installed with the nuts pointed up, rather than inside the crossmember.
I’m assuming that’s not correct...any issues I need to look for when I remove the old mount?
Old Aug 24, 2018 | 10:21 AM
GeneralDisorder's Avatar
Re: L98 engine mounts
The energy suspension poly mounts aren't real expensive.....
US made too.
Old Aug 24, 2018 | 10:23 AM
Car: 1988 IROC-Z
True, but I’d rather avoid the issues, particularly the vibration and harshness the poly mounts tend to introduce.
Old Aug 24, 2018 | 10:28 AM
Make your own with pourable urethane. Can get it in many durometers. Then it will be made in USA and tuned to your specific vibration preference.
https://www.smooth-on.com/
GD
Old Aug 24, 2018 | 05:19 PM
Drew's Avatar
I used Energy Suspension motor mounts in my 86 T/A, no vibrations of NVH issues that I could discern. Already got another set on the crossmember going into the project bird. I haven't noticed that many people complain after using the Energy Suspension mounts.
Old Aug 24, 2018 | 06:45 PM
My experience with urethane mounts has generally been very positive. It's a V8 and as such if it's got much vibration it's probably got a misfire or uneven compression.
GD
Old Aug 24, 2018 | 07:43 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I have Prothane inserts in my LS swap, I don't notice any additional NVH in my car
Thridgen60
LSX and LTX Parts
Nov 13, 2016 10:03 AM
83C_CamAroZ28
Sep 28, 2010 04:24 PM
427camaro
Feb 22, 2002 06:16 AM
