Multi Spark Ignition Timing?
Old Aug 29, 2018 | 10:32 AM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Want to pick some brains here for a second.
The multi-spark ignition system in my car is sort of a hybrid system that utilizes a capacitive discharge box in conjunction with the stock inductive system. The primary spark is still provided by the inductive ignition (Turn-key Davis Unified HEI) and the second, capacitive spark is then provided by the CD box. This way you get both the benefits of an inductive spark at low RPM and a capacitive spark at high RPM. Multiple sparks are provided throughout the entire RPM range this way and do not drop off to a single spark after a certain RPM. Also, if the box ever fails, the ignition is still able to fall back onto the stock system.
Anyways, million dollar question time. My CD box offers a CAO (Crank angle offset) feature that allows you to adjust exactly how many degrees after the primary spark that the second capacitive spark is fired. It is adjustable in 2* increments from 2-18* AFTER the primary spark. With my timing tables already optimized at 36* total, common sense dictates that I'd want the secondary spark to be as close as possible to the primary spark with either a 2* or 4* setting. However, can too close be too much?
Old Aug 29, 2018 | 10:51 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Multi Spark Ignition Timing?
Unless you have a dyno to play on, you're just guessing if it will do any good or harm.
Old Aug 30, 2018 | 06:59 PM
Car: 1985 Z28
I'm not really looking to gain performance with the setup. I'm a firm believer that two sparks aren't really better than one in the performance department.
My primary intent is to make the ignition system more robust and fail-safe.
dpmalibu
Jun 4, 2016 09:07 AM
BlkBird408
Mar 5, 2006 12:24 AM
CHEVYTOWN
Sep 8, 2002 09:22 PM
JPrevost
Apr 18, 2001 01:35 PM
MikeH
Jul 31, 2000 12:26 PM
