Part Number 17092109 Evaporation Canister
Old Sep 1, 2018 | 07:19 AM
1991vortech335's Avatar
Car: 1991 Convertible Z/28
Engine: Vortech 335 TPI
Transmission: Trans-Go 700-R4
Hello ThirdGen!!!
just throwing this out there.....
Might anyone know where I can order a replacement evaporation canister? I’m in Canada and require one to meet emissions but am unable to get one from anywhere up here including wreckers! I’ve tried Summit and Jegs to no avail. The one in my Z weighs about as much as a cinder block and I believe is the culprit for throwing a code but I can’t be certain as my car is modded pretty heavy (supercharged, custom tune ect) I have new TBS and O2 and EGR. Thank you all ahead of time!
Old Sep 2, 2018 | 09:50 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
Re: Part Number 17092109 Evaporation Canister
FYI the buicks and I think oldmobiles in the 80s/90s used the same evap canister, in case you are searching ebay etc. But if you cant find it, you can convert to what the trucks use pretty easy. The canisters are the same diameter, just a few inches taller and they dont have the solenoid built in. They are also still manufactured.
The connector/plug on the solenoids are the same, so its plug and play. But you would need to get some rubber hose or fuel line to run from the canister to the solenoid since like I said they are separate parts. A little reconfiguration but at least you get new equipment.
https://www.autozone.com/engine-mana...ster/91192_0_0
https://www.autozone.com/engine-mana.../6542_159945_0
miller626
Carburetors
Oct 7, 2009 01:45 AM
german-motorsport
Feb 15, 2003 01:00 PM
xanax
Dec 26, 2002 12:48 PM
