Headlights not working.
Old Sep 2, 2018 | 10:18 PM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Axle/Gears: 3.23 Torsen
Went to turn my headlights on but later noticed they were not turning on. Everything else works except headlights. Headlight switch the problem?
Old Sep 10, 2018 | 02:25 AM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Re: Headlights not working.
Replaced headlight switch on my 92 and still not getting power to my headlights. Tail lights, turn signals, brake lights, emergency lights, dash lights all work except headlights. Never encountered this problem before. Has anyone ever had this happen? What was at fault help..
Also on my 88 I have a weird problem with headlights. Low beams on and only driver side turns on.... If I turn on the High beams, all four light up good. Turn off high beams and only driver side goes on. What's the deally? I don't know were to start looking.
Old Sep 10, 2018 | 08:23 AM
92RS-HeritageEd's Avatar
Car: 92 RS / 90 IROC-Z
Engine: 305 / 350
Axle/Gears: Non-Posi / Posi - Both GU2 - 2.73
Check out the links below,
http://austinthirdgen.org/mkportal/m...ody_wiring.gif
Those should help you trace back the electrical issues your describing. On my 92, when all headlights quit working one day I found it to be the Hi/Lo Beam Switch mounted to the steering column under the dash.
Old Sep 12, 2018 | 01:09 AM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
It was the low beam high beam switch. Thanks.
Old Sep 15, 2018 | 04:38 PM
L.A. CROSSFIRE's Avatar
Car: 1991 camaro Z28
Engine: 5.7L
Transmission: turbo 350
That would be the dimmer switch right ? This happened to me last night, so are you guys testing it before you take it off ? Any good instructions on taking it off... I know its a very tight fit under there.
JimmyG-91Z
Jul 17, 2003 04:21 PM
wa90formula350
Feb 4, 2002 07:15 PM
silentneko
Nov 28, 2001 09:49 AM
mm4tt
Oct 14, 2001 06:17 PM
MILT
Aug 16, 2001 12:50 AM
