Hard line from the wiring harness
Old Sep 13, 2018 | 07:44 PM
micktroup's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7L V8
Transmission: auto
Another victim of my engine fire was the hard line that comes out of the harness and attaches to a vacuum line, feeding into a little two way valve(that also got destroyed). I've replaced the valve and some of the vacuum lines, but as to the hard line out of the harness: it burned up and I can't seem to find where it comes out of the harness. Does anyone know where it routes from- I assume it comes through the firewall SOMEWHERE from the HVAC, but I can't see where. Or do I have to dig out what is left of it from the harness and connect a vacuum line to it? I would rather find where it comes into the engine bay and route directly from there...
Old Sep 14, 2018 | 07:12 AM
Re: Hard line from the wiring harness
It is part of the HVAC harness, which comes through the firewall near the heater hoses.
There should be 2 of those in that harness: one brings vacuum from the accumulator to the control head, and the other takes it from the control head to the heater control valve.
Very eeeeeezy to just pop the ENTIRE harness out, from the control head all the way to the blower, compressor, etc.; and just repair it. Replace the existing hard line with the same, using a short piece of hose as a splice, where needed. Repair the electrical parts that are damaged at the same time, if any, of course.
michael
17
Jun 25, 2015 08:36 PM
Mike86Z28
Jul 2, 2004 10:13 PM
