TPI bracket? What am I missing?
Old Sep 17, 2018 | 05:49 PM
kentuckyKITT's Avatar
Car: 2 T-Tops
Engine: 327/305
Transmission: TH350/700R4
Axle/Gears: 3:42/2:73
Quick question. In the image below as pointed out by the white arrow, what am I missing there? Anyone have a part number or know where I can find one? I have this little black post between the runners and I assume something goes on this to hold those cables? Thanks!
Old Sep 17, 2018 | 05:58 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: TPI bracket? What am I missing?
There is a spark plug wire retainer for this to hold the tv and throttle cable.
gm 8917256 is Nla you should post a ad in the wanted section .
https://m.ebay.com/itm/NOS-OEM-GM-Sp...kAAOSwnqhbcdd5
Old Sep 18, 2018 | 06:43 PM
Car: 2 T-Tops
Engine: 327/305
Thanks for the info! I had a feeling it was no longer available. Is it similar to this: https://www.ebay.com/itm/Dorman-40289-HELP-Spark-Plug-Wire-Retainer-Made-from-High-Quality-Materials/332729688415?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20131017132637%26meid%3D35210c20fbcc4581b70d2d30d13b346d%26pid%3D100033%26rk%3D3%26rkt%3D8%26sd%3D332729688415%26itm%3D332729688415&_trksid=p2045573.c100033.m2042
Or does it have more than two holders like that auction you posted?
I'll post an ad in the wanted!
Old Sep 18, 2018 | 07:44 PM
Drew's Avatar
It's a three holer normally. I wouldn't waste your time trying to find a used one. I've kinda lost count of how many I've put on my Formula, and they generally don't snap closed tight enough to keep the throttle cable from popping it open.
Old Sep 19, 2018 | 08:25 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I wrap a small zip tie around the middle of the black clip
DanielRicany
Feb 19, 2018 07:33 AM
Malicious3rdgen
Oct 28, 2013 01:43 AM
TPIMonteLS
Jun 23, 2012 06:12 PM
MINT1982CFI
Oct 14, 2003 09:25 PM
noc_81
Jul 28, 2003 02:22 AM
