96 355 vortec stock crank w/2bolt mains max rpm?
From: Close to Boggstown Indiana ( out in the middle of a corn field)
Car: 89 Iroc, saved from scrapyard
Engine: 350 vortec w/stealth ram
Transmission: 85 corvette 700r4
Axle/Gears: 3.73 posi
Hi guys, been a long time....... think I spun a bearing on my vortec build. I over revved it on full pulls w/tach hitting up to 7,300-7,500 several times. I assume that's too much for stock internals , anybody know the general rpm limit with 2 bolt mains and cast crank?. Just trying to decide how to upgrade. Anybody know if stock 4 bolt main vortec with steel crank exists in junkyards or would it be only aftermarket options?
Thanks in advance. Sorry if dumb question.
Car: 1983 G20 Chevy
Transmission: 4L60
Re: 96 355 vortec stock crank w/2bolt mains max rpm?
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Bummer on the spun bearing. Rod bearing ?
Car: 1983 G20 Chevy
Transmission: 4L60
I thought that all the 2500 series had 4 bolt mains and the typical cranks. The first four bolt main I had was out of a 2500 van. If you found an old police vehicle I've read that they were 4 bolt mains with a forged crank. David Vizard has published lots of tests with stock equipment that shows it can sustain a few high rpm or high power runs but in the end it goes. I'd also keep it under 6500 and refrain from lots of high rpm exercises with a 2 bolt block. I'd imagine bearing clearances will become very critical if you go this route.
Well I feel a little dumb but great news.............
Originally on last drive I was doing a WOT from dead stop and O2 sensor blew out of header ( only about 1/2 a turn in there with boogered up threads). I limped it home sounding terrible. Fixed o2 and threads, let down jack, slipped a little as it went down hard and didn't think too much about it. Fired it up and immediately had loud knock in rhythm with a rod. thought it was toast after I felt bottom of oil pan and felt vibration.
Well you probably know where this is going..... got to thinking and looked at really good today.... the jack slipped off crossmember, hit center link and smashed into very front of oil pan. JUST A DENTED OIL PAN!
So now I just have to search oil pan removal and see if I can change out without pulling motor.
I'm going to get parts ordered and get her fixed. Much better than a shortblock build!
Thanks for responses guys, still very good info learned.
And good to hear from you Brian! You're creation is still alive and well! ( Lots of others helped with great info on here but you by far the most)
Engine: Lb9
Transmission: M20
Thanks Gary, hope you and your family are doing well. Time to hit the dyno to see what it puts down
to bad about the pan but things could have turned out worse .
oil pan changed! Gonna finish it up tomorrow but may run to town open headers to see if I get pulled over first!
Car: 1994 Z28
Engine: 355 LT1
I spun a 2 bolt main (1997 block) to 6,300 RPM for years. I even whacked that motor with a 100 shot often.
Car: 90 Formula 350
Axle/Gears: Dana 44 3.54
The PM rods used in the later SBC were stronger than the old Pink rods
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
I bet you had some serious valve float too, just assuming stock valve springs were in place.. OUCH!!!!!
Engine: Lb9
Transmission: M20
He’s using Alex vortec springs
Sorry guys, I responded last night but must have forgot to hit "reply" after typing.
I ended up going with the Vortec Alex spring kit that was a little more cost effective. I believe that kit allows me up to .550 lift. Max lift on my cam is .530. I'm running 1.52 rockers. That gives me wiggle room on maximum allowed. Coil bind is listed @1.145.
If I can go up to .550 lift and I'm .020 under on that measure alone and running stock ratio rockers based on that figure I should be good.
Just wanted to make sure I wasn't doing a big "no no" by opting to go a smidge on the tight side ( -0.005) of the target spring height.
Engine: Lb9
Transmission: M20
TVP122
Dec 4, 2013 05:49 AM
FlippindaBird
Jul 13, 2011 12:43 PM
tilstad
May 15, 2004 08:52 PM
