injector selection help
Car: 1992 z28
Engine: 305 tpi
Hey.
I Have had heaps of help on here so far so ill try my luck again.
Im putting together a new engine for my 92 camaro, its a crate zz6 with a first tpi intake and probably the ebl p4 ecm. I need to get some injectors for it and im looking at these.
Accel PART# 150830 14.5 ohm injectors. My question is will they work considering the stock ones were 16 ohms?
thanks in advance
thanks in advance
Re: injector selection help
since you need to tune for the injectors, this is another good choice. You would need to check with soothsay to see if the adapters are needed for first installation.
https://www.southbayfuelinjectors.co...brand_brand=19
85z28kid
06-12-2011 07:35 AM
