Pushrod clearence
Old Oct 7, 2018 | 06:50 PM
scamaro355's Avatar
Car: 92 rs
Engine: 355 stealth ram, dart heads, S480
Transmission: 4L80E
Pushrod clearence
anyone running dart heads had problems with the pushrod hitting the intake runner and causing alignment problems??
Old Oct 7, 2018 | 08:07 PM
GeneralDisorder's Avatar
Re: Pushrod clearence
Sometimes you need to loosen the studs and move the guide plates....are the guide plates the right size for those heads? Sometimes aftermarket heads have the valves stems in slightly different places than stock heads to facilitate port sizing, valve sizing, etc.
it's to got be the choice of parts. Either the guide plates or the rockers. Push rods are just straight tubes, and the location of the valve stems and the lifters are the last thing I would suspect. Something about those rockers or guide plates are not matching up to those heads.
GD
Old Oct 7, 2018 | 09:13 PM
scamaro355's Avatar
Car: 92 rs
Transmission: 4L80E
The guide plates are the ones that came
with the heads. Since the engine is still on the stand. I pulled the guide plates off and still have the same problem. The push rod is hitting the intake port on the head. Def a head problem. Time to grind or look into .150 offset rockers for the intake vales.
Old Oct 7, 2018 | 11:25 PM
https://www.google.com/url?sa=t&sour...KPQYswxQPadwW0
Looks like you may have to modify the head.
GD
Old Oct 8, 2018 | 06:46 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
What size pushrod?
its not uncommon to have to use adjustable guideplates when setting up heads. 5/16 shouldn’t have an issue but more common with 3/8” and larger
if pushrods are correct length and its still hitting i would just grind abit. Use a sanding roll
Mkos1980
Nov 27, 2001 11:59 PM
Bunker82
Oct 10, 2001 10:03 AM
SCOTTCAMARO1
Sep 6, 2001 09:33 PM
APCAMARO
Dec 4, 2000 07:01 AM
