Fuel pump question
Old Oct 25, 2018 | 06:34 AM
iroczz89's Avatar
Car: 1989 irocz convert
Engine: 383 tpi
Transmission: 4 spd auto
Fuel pump question
Help!! Does my 89 Z28’s fuel pump have a relay and a fuse or just a relay and where are they located?
Old Oct 25, 2018 | 09:57 AM
Grandpa's Avatar
Car: 1990 Camaro RS 3.1L
Engine: 3.1L v-6
Transmission: 200R4
Re: Fuel pump question
It should have both but the relay is between the brake booster and the fender on the firewall grey oval shaped. Fuse is in the fuse block.
Old Oct 25, 2018 | 10:50 AM
iroczz89's Avatar
Engine: 383 tpi
I see 3 relays between the master cylinder/ firewall and one mounted on the passenger fender next to the battery. Which one powers the fuel pump?
Old Oct 26, 2018 | 02:12 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
On my car and I think yours as well the two identical ones are the fan and fuel pump relays. Fan relay has four wires going to it, the fuel pump
relay has five. If you have two fans the other one may be the relay for the other fan also with four leads to it
kowboy59
Nov 7, 2011 09:36 PM
Twilightoptics
Nov 18, 2002 01:26 PM
BuckeyeROC
Apr 29, 2002 07:18 PM
makinemtap
Jan 30, 2002 01:09 AM
442guy
Apr 13, 2001 04:58 PM
