valves seals, injectors and intake gaskets,what else?
Car: 1988 IROC
Engine: LB9
Hi all,
Car is 88 IROC 305 TPI. After searching old posts and gathering information I have begun the work of replacing the manifold gaskets ( typical anti freeze leak in the corner) , replacing the fuel injectors ( Hot start issues due to leaking and using South Bay) and valve seals. What a PITA that passenger side valve cover was! but it is off. Have a few questions. Car has 70K miles, 100% stock and been well maintained. I am looking at the EGR valve which as you know is buried in the intake. Should i consider replacing it while I have it apart or are they trouble free and leave it alone? Anything else I should while up to my waist in it? . Id much rather do it now rather than have it apart again.
Thanks in advance!
Thanks in advance!
Re: valves seals, injectors and intake gaskets,what else?
Fuel pressure regulator.
Stainless allen bolts for runners, intake, etc
Bead blast the intake manifold mating surfaces - you will find a lot of pitting in the corners that causes these leaks. Fill with metal epoxy and block sand smooth.
GD
GD
Car: 1988 IROC
Engine: LB9
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
Is there a way to check for the anti-freeze leak? I'd rather not go back into mine but I've never had it off though I am losing a little coolant regularly. Maybe just spray the area with carb cleaner and listen for RPMs?
butchc, I was in the same boat. Mine had 118,000 almost completely unmodified. Found that the timing chain set was really slack. Fixed a big time idle hunting problem. An easy way to check is to see if your base timing floats around at idle. That is the cam "flopping" on the slack chain under the valve spring pressure.
And yeah - on these old small blocks - the timing chain is an every 60k event if you want it to run right and the timing to be solid. That's a totally different job though.
GD
Car: 1988 IROC
Engine: LB9
Like GD mine leaks were easy to detect. Nothing ever hit the floor and nothing in the oil but the anti freeze smell was strong. Mine was leaking at both front corners.
Not going any deeper into the motor, I am too old to live bent over a fender, LOL
Engine: 350 TPI L98
Transmission: WC T5
Can that coolant also leak into the intake runners?
86FyrBrd
Sep 28, 2002 08:47 AM
daniel dekay
Apr 6, 2001 01:40 AM
