Won't start when I screw up sequence
Old Dec 3, 2018 | 05:45 PM
JJake's Avatar
Car: 1992 Camaro RS
Axle/Gears: 3.08
1992 Camaro RS 305/5spd, computer removed converted to carb. Starts if I remember to push in clutch with trans in neutral. If I forget to put in neutral it doesn't turn over and won't turn over until it sits undisturbed for a few minutes and I do the sequence correctly. Is there a solution or do I put a sticky note on the dash?
Old Dec 3, 2018 | 06:04 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Won't start when I screw up sequence
I believe the short answer is to jump out the VATS starter enable relay .
You are a 1992 , so you have VATS .
You eliminated the ECM and went to carb , so no problem with the fuel side of VATS , but if the starter side wasn't addressed as per my short answer above , VATS could be killing the starter , depending on the degree of wiring bukake that was performed in the ECM removal .
Old Dec 3, 2018 | 07:46 PM
JJake's Avatar
Car: 1992 Camaro RS
Axle/Gears: 3.08
If I remember correctly, there is what looks like a relay behind the drivers side kick panel. Is that what I jump out with a wire or cut it out and connect the wires?
Old Dec 3, 2018 | 08:08 PM
OrangeBird's Avatar
Car: 1989 Firebird
If you have power door locks there are likely to be two relays in that area if I recall correctly . The relay you want it the one that has a fat yellow and a fat dark green wire as per this diagram (see "Starter enable relay" at the lower right hand side of the schematic) . Cut those two wires from the relay's connector and connect them together (preferred method being a soldered "western union splice" covered with heat shrinkable tubing in the appropriate size) and that will eliminate whats left of VATS .
Old Dec 3, 2018 | 08:35 PM
JJake's Avatar
Car: 1992 Camaro RS
Axle/Gears: 3.08
Thank you, it will give something to do tomorrow.
Loki
May 26, 2010 09:21 AM
ellocojorge
Interior Parts Wanted
Dec 9, 2009 10:35 PM
B4Ctom1
Nov 2, 2004 01:48 AM
12sec305
Dec 10, 2001 01:33 PM
irocz_ca
May 4, 2001 09:42 AM
