Does a 1986 Lg4 V8 have a starter support?
Old Dec 16, 2018 | 10:06 AM
Alfisti's Avatar
Car: 1986 Contempo Cantara Camaro
Engine: LG4 5.0 V8
Transmission: T5 5 -speed
The starter on my Camaro stopped working the other day and when I got under the cat to give it a whack I found a loose wire that was touching a bracket that was hanging down.
There is a hole on the bracket that fits over one of the bolts on the starter solenoid But I have never seen a support attach to a starter solenoid.
So is this bracket needed? Is it stock? Is it supposed to be attached to the starter or did the PO put it back incorrectly
I reattached and heat shrinked that wire and the starter is working again.
Thanks!
Ian
Old Dec 16, 2018 | 12:41 PM
Re: Does a 1986 Lg4 V8 have a starter support?
Yes, that bracket is stock, and while you may not absolutely "need" it, it is a very very good thing to have. The one starter bolt is supposed to be a stud, and then a nut holds the bracket to it.
Old Dec 16, 2018 | 05:12 PM
Alfisti's Avatar
Engine: LG4 5.0 V8
Cool, thanks! I pulled it off for now just so it's not whacking the wires, but I will figure out what size nut it needs and put it back on.
Old Dec 17, 2018 | 12:30 PM
OrangeBird's Avatar
Car: 1989 Firebird
Yep , that bracket may well save your starter ....
Old Dec 17, 2018 | 04:05 PM
Alfisti's Avatar
Engine: LG4 5.0 V8
I saw your earlier post about the wire. I'm pretty sure it was shorting on the loose bracket, I wasn't even getting a click when I tried to start it.
The sketchy butt connector was so loose on one side the wire pulled out easily. So it's soldered and heat shrinked now, I just didn't photograph it as I was in a hurry.
Next up is tightening the exhaust the PO installed. It has already come loose once!
Old Dec 17, 2018 | 06:30 PM
The nut is yerbasic ¼"-20 (std thread).
Waramp
May 5, 2011 11:28 PM
Redwhisper
Jun 28, 2006 10:12 AM
BrianI
Jul 17, 2003 10:49 AM
david auster
Sep 17, 2002 01:23 PM
Golden80
Aug 29, 2001 02:16 AM
