83 305 engine v-belt routing. Which pulleys?
Old Dec 22, 2018 | 09:08 PM
Camaro-3's Avatar
Hi,
For a 83 Camaro with these accessoires : alternator, PS pump with 2 grooves, and a/c... Without Factory smog pump (CAN version)...
Do you have pictures of the belt routing? Which Water pump pulley I need? Double Row or triple Row? My single Row seems to not work actually.
All pulleys are for v belts... And i have 3 groove of m'y crankshaft pulley.
I never had a/c and want to install one, thats why im wondering...
Here is a picture I Seen on internet... I want the same installation but not need the smog pump.
Which GM part number I need for the Water pump pulley? Probably a 2 groove, but it seems There is different models and the groove are not at the same place for all 2 groove gm wp pulleys... It would be Nice to have a picture of optimal Water pump pulley to find the right one at the junk yard. Ideas? Do you have aa clear pictures of v belt routing? Right here on the picture (second one) im not sure if There is 2 or 3 grooves on water pump pulley including the groove for the smog pump. Also, the first picture Say There is 4 tracks, so i assume the CS pulley and WP pulley grooves are offset?
So I need to find the right number of grooves and also the right offset for WP pulley...
Old Dec 23, 2018 | 12:47 PM
Camaro-3's Avatar
Re: 83 305 engine v-belt routing. Which pulleys?
Anyone have the same early setup with all v belts, a/c and without air pump?
Old Dec 23, 2018 | 04:11 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
My car has a/c and no smog-deleted that long ago-water pump pulley I used was off a ~1982 chevy pickup and same as v-belt 3rd gens used,except does not have the small front pulley for smog-just 2 grooves of same diameter.Crank pulley should have 3 grooves of same diameter.Any chevy car/light truck~1978-early 1985 SBC with R4 compressor should have correct pulleys.I could get a pic of my setup and or P/N of W/P pulley if needed
Old Dec 23, 2018 | 04:34 PM
Camaro-3's Avatar
A pic of the setup would be Nice! Especially the fan pulley.
Old Dec 24, 2018 | 08:24 PM
NoEmissions84TA's Avatar
I have some numbers for you that might help. I do not have the number of the 2 V groove WP pulley, though.
From my 84 Trans Am: 4 V belt setup
WP 1403 7740 has 3rd groove for air pump
Crank 1402 3143 3 grooves
If you were to convert to the mixed V belt and flat multi-ribbed for the ALT setup (ALT on pass side):
WP 1408 8685
Crank 1408 8683
Old Dec 26, 2018 | 11:41 AM
Camaro-3's Avatar
Thank you very Much for the info. I Will be ok with my 2 groove WP pulley and my 2 groove PS pulley.
sflthndrckn
May 15, 2019 02:10 PM
Paint-it-Black
Nov 30, 2007 05:42 PM
I-Roc with my Z
Jan 21, 2005 03:34 PM
formula91
Southern California Area
Jun 18, 2002 10:35 AM
bleak
Jan 19, 2001 08:48 AM
