Dropping compression. New pistons or heads
Old Jan 25, 2019 | 07:03 PM
2slow5.0's Avatar
Car: 91 Formula
Engine: 5.0 tpi slow
Transmission: WC t-5
Currently running 10.2:1 on a 358 with a set of trimmed down fast burns. 60cc chamber. Id like to get down to 9.5:1 or under for some forced air. What cc chamber would put me there or should i just swap slugs? Currendly running ross forged pistons. A head swap needs to be a raised port for a 1206 intake gasket to match my intake
Old Jan 25, 2019 | 08:12 PM
NoEmissions84TA's Avatar
Re: Dropping compression. New pistons or heads
An 8cc chamber increase will drop your CR by .81.
Old Jan 25, 2019 | 08:43 PM
2slow5.0's Avatar
Car: 91 Formula
So going to a 65cc chamber with I think a .010 thicker gasket should get me close to where I think I should be? I'm unsure of the adverse effects of running a thicker gasket, or if my math is correct??
Thanks for the input
Old Jan 26, 2019 | 05:57 PM
You're welcome. I don't know how thick your head gasket is now, but you should try to keep the quench close to .040".
Old Jan 27, 2019 | 11:11 AM
skinny z's Avatar
As an example:
4.04 x 3.48
60 cc head
5 cc piston
.040 x 4.100 gasket
.025 piston below deck
Result is a CR of 10.26:1
A 64 cc head nets 9.8
A 60 cc head with a .060 gasket nets 9.78:1
The input values are a best guess but typical SBC. Verify your piston valve relief/dome/dish volume. Going from 5 cc (2 valve reliefs) to 9 cc (which I haven't come across) drops the CR to 9.8
Old Jan 27, 2019 | 11:21 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
How much boost and what kind of poweradder?
low boost i’d send it as is at 10:1. I would try thicker gasket first. Ease up on tune, keep engine cool and good intercooling
High boost throw c16 in it or e85
Old Jan 27, 2019 | 11:29 AM
2slow5.0's Avatar
Car: 91 Formula
Gootta go back to my build sheet from a few years ago. Im pretty sure it was a.028 head gasket. I was thinkin of throwin some new afr's on whick would gain me 5cc oin the chamber. Ithimk at least 10psi intercooled. Id prefer not to swap pistons. But i will need be. Tryin to stay at 93 octane. E85 not too common around here.
Old Jan 27, 2019 | 11:30 AM
2slow5.0's Avatar
Car: 91 Formula
Cog drive vortech. Intercooled
Old Jan 27, 2019 | 11:40 AM
skinny z's Avatar
Originally Posted by 2slow5.0
Gotta go back to my build sheet from a few years ago. I'm pretty sure it was a.028 head gasket. .
It'd be tough to hit only 10.2:1 with a .028" gasket / 60 cc chamber all else being equal and standard SBC. Before you get too far you'll want to verify the values. With the above data listed a .028 gasket gets you over 10.6:1. Change the valve relief volume to 7 cc and a .028 gasket nets 10.3.
But like I said, there are too many variables to just guess. And I'm even guessing on the bore and stroke.
Old Jan 27, 2019 | 11:58 AM
2slow5.0's Avatar
Car: 91 Formula
Yea. Why im tryin to find the build sheet. Its an oddball shortblock. 3.50 stroke, 5.85 rod and a 4.040 bore. I had to have the pistons made back when originally pieced together. But unfortunately Ross doesnt have the record. I do remember cc-ing the heads and calculating the 10.2:1 with Ross. I know the build sheet is here somewhere.
Old Jan 27, 2019 | 12:00 PM
2slow5.0's Avatar
Car: 91 Formula
On a ebl flash I never had any detonation issues on 93. Even goofin up and runnin too much timing at first
Old Jan 27, 2019 | 01:14 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
If its 10.2 on a .028 gasket then go with a .040-.051 and let it eat. Not even concerned with 10 psi intercooled
Old Jan 27, 2019 | 01:31 PM
2slow5.0's Avatar
Car: 91 Formula
I've deffinetly gotta dig in and see exactly what I got. I figured it could be a good excuse to upgrade the heads/ cam
Id prefer to not tear the bottom end apart if possible
S10Wildside
Jun 25, 2004 10:38 PM
CamarosRUS
May 15, 2004 12:57 PM
Jim85IROC
Nov 27, 2002 09:09 AM
JadesAn89
Sep 3, 2002 12:32 PM
ChrisFormula355
Jun 24, 2002 11:22 PM
