Relay ????
Old Feb 4, 2019 | 03:50 PM
tcrisp's Avatar
Car: 1989 camaro iroc
Engine: 350 tpi
Transmission: auto
Axle/Gears: 323
Relay ????
Need help identify these relay in pic info in car is 89 Camaro Iroc 350 tpi
Old Feb 4, 2019 | 04:06 PM
Drew's Avatar
Re: Relay ????
I'm just going to shoot from the hip on this one, so verify before you take it as gospel...
The flat one on the left in back is the ESC module for the knock sensor.
The square one on the left in front of the ESC is for the MAF.
The square one on the right is probably for fog lights.
Of the other two, one should be the fuel pump relay. The other is probably a fan relay.
Really though, your best bet is to get a GM wiring diagram for your make/model of car, and cross check the wire colors with what the manual shows running to each suspected relay. You can guess based on location of where the relay is mounted, but seeing as how it's 2019, who knows what a previous owner may have moved around. Wire colors on the other hand, don't usually lie.
Old Feb 4, 2019 | 07:02 PM
88 TA's Avatar
Car: 88 T.A.
Re: Relay ????
Found this before on this site before. Hope it helps
Old Feb 4, 2019 | 07:17 PM
tcrisp's Avatar
Engine: 350 tpi
Transmission: auto
Axle/Gears: 323
Re: Relay ????
My or different than the one in that pic
Old Feb 4, 2019 | 07:44 PM
88 TA's Avatar
Car: 88 T.A.
Re: Relay ????
not sure. Sorry
Old Feb 4, 2019 | 09:09 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Re: Relay ????
The picture is right. In your pic the one unplugged is the orginal fuel pump, the one laying loose is the current fuel pump.
Old Feb 4, 2019 | 09:30 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Relay ????
The wires on the maf burn off sure look frayed.
Randy82WS7
Jun 9, 2003 11:08 AM
Iroc_Z28
Jan 28, 2002 05:41 AM
JT 85 TA 305
Dec 8, 2001 06:15 AM
88gta305
Feb 1, 2001 03:48 PM
