Serpentine alternator options.
Old Feb 22, 2019 | 04:38 PM
seiplentz's Avatar
Car: 85 Z28
Engine: GMPP 350 HSR
Axle/Gears: 4th gen 3.42 Posi LS1
My alternator isn’t fitting on my new engine setup. The battery stud hits the valve covers. Anyone using a slimmer style alternator?? I have aluminum heads with spacers to use perimeter style valve covers.
Old Feb 22, 2019 | 07:49 PM
ULTM8Z's Avatar
Re: Serpentine alternator options.
not sure how you're going to solve that with a CS 130. it looks like the stud is already clocked about as far as itll go.
what you can do is swap out to an AD244 style. its physically bigger and puts the stud farther away.
search on AD244 and you'll find a few threads on how to do the swap.
Old Feb 23, 2019 | 12:44 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
LT1 valve cover....... ?
Old Feb 23, 2019 | 02:07 PM
seiplentz's Avatar
Car: 85 Z28
picked up that ad244 alt. Seems to clear the valve cover. Thanks for the tip!!!
Old Feb 23, 2019 | 02:52 PM
ULTM8Z's Avatar
Cool. You'll love the performance of that thing. You literally CAN'T get it to below 14.2 volts even at idle with every last accessory and system turned on full power.
Old Feb 23, 2019 | 07:21 PM
seiplentz's Avatar
Car: 85 Z28
I cant wait!! I always had a voltage drop problem.. Thanks so much for the help. It made it an easy find for once!!
Old Feb 28, 2019 | 06:58 AM
seiplentz's Avatar
Car: 85 Z28
Finalized the mounting. Whew it is still very close to the valve cover. But it doesn’t touch!!
Old Feb 28, 2019 | 11:01 PM
ULTM8Z's Avatar
those must be some seriously tall rocker covers...
Old Mar 1, 2019 | 07:43 AM
seiplentz's Avatar
Car: 85 Z28
They have spacers on the heads to convert the heads from center bolt to perimeter bolt valve covers. They are probably a 1/2" thick.
https://www.summitracing.com/parts/icb-551542
Old Mar 1, 2019 | 08:05 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I use the stud type with my cast tall covers and its tight but works. .
Old Mar 1, 2019 | 09:24 PM
xylorex's Avatar
Car: 1987 GMC 1500 4x4
Engine: 383 roller, MPFI ecu by FAST
Axle/Gears: 3.73 Eaton Trutrac 30 spline convsn
I had the same problem with a powermaster alternator on my new engine build.... you can actually rotate or "clock" an alternator, pull out the screws and rotate the rear housing.
Old Mar 6, 2019 | 09:21 PM
seiplentz's Avatar
Car: 85 Z28
Before starting a new thread can anyone clear up wiring the ad244? What I gather all i need to do is wire the S wire to the battery or fuse box?
Old Mar 6, 2019 | 10:43 PM
ULTM8Z's Avatar
https://www.thirdgen.org/forums/electronics/755380-ad244-conversion-took-plunge.html
Old Mar 7, 2019 | 06:52 PM
seiplentz's Avatar
Car: 85 Z28
I Read that article. I was using a 1 wire alternator. So if i gather this right I can take the L wire add resister and loop it to the output and it should work?
Old Mar 7, 2019 | 08:55 PM
ULTM8Z's Avatar
no you need to have the sense wire (the L terminal) hooked up to the switched ignition that way the voltage regulator knows what output it needs to supply to keep the system voltage up over 14V
if you do it like you're suggesting you're likely to see something like low 13V at the battery and possibly less than 13 on the ignition side.
J0hn_J0hn08
Mar 16, 2015 07:59 PM
Chuck84TA
Nov 5, 2014 09:36 PM
Veaceonee
Jan 19, 2013 10:19 PM
Bazookajoe254
Feb 20, 2007 10:48 PM
Nitro Don
Apr 27, 2001 08:24 AM
